Difficult to know where on the forums to post this…
I have tried the face-recognition sample, on git, and it all works fine!
I have used DIGITS, created a huge trainset (from VGG_Face) and tested it using DIGITS, it works as expected - I then deployed it, ran the code against the above sample and it failed in tensorNet.cpp
for (auto& s : outputs) network->markOutput(*blobNameToTensor->find(s.c_str()));
The blobname was bboxes_fd - I presume this fail for all of the blobs?
How did the recognition model get trained? How do you add the IPlugin layer and blob fields into the network - when I try it complains about unknown layer type IPlugin
I am trying write a plug in layer, as per the above, So thats why I ask, how did you train it so I can get my set working with the sample code?
I used nvCaffe with GoogleNet.
Thanks for the reference links - very helpful. I did think it maybe a merged net but wasnt sure that it was possible!!
Did you facenet that comes with the jetson-inference sample of did you retrain with the FDDB? I have created my classification network and was hoping to just merge with the facenet detection network?
YES. facenet is trained with FDDB.
Try to follow the steps shared in comment #2 and you should be able to get a merged net.
Yes working through this now. Creating a detection network is new to us, so picking our way throught it.
I presume the training was done in DIGITS? So, again, I presume the FDDB structure has to be converted to KITTI and then start the training?
I have tried the face-recognition sample, on git. However, I met some problem like ‘vector’ is not a member of ‘std’ with jetpack3.3 and Jestson TX2. Is that caused by different jetpack version or other reasons? Must I use the jetpack3.1?
Have you include the vector header in your source code?
#include <vector>
Which file do you mean? I just try the sample as the github said.
$ sudo apt-get install git cmake
$ git clone GitHub - AastaNV/Face-Recognition: Demonstrate Plugin API for TensorRT2.1
$ cd Face-Recognition
$ mkdir build
$ cd build
$ cmake …
$ make
And the error is as bellows:
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:5:45: error: ‘std::vector<bboxProfile*> RecognitionLayer::bboxTable’ is not a static data member of ‘class RecognitionLayer’
std::vector<bboxProfile*> RecognitionLayer::bboxTable;
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:6:44: error: ‘std::vector<tagProfile*> RecognitionLayer::tagTable’ is not a static data member of ‘class RecognitionLayer’
std::vector<tagProfile*> RecognitionLayer::tagTable;
In file included from /usr/include/c++/5/cassert:43:0,
from /home/nvidia/liuningjie/Face-Recognition/build/aarch64/include/pluginImplement.h:4,
from /home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:1:
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp: In member function ‘virtual nvinfer1::IPlugin* PluginFactory::createPlugin(const char*, const nvinfer1::Weights*, int)’:
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:24:16: error: ‘mBboxMergeLayer’ was not declared in this scope
assert(mBboxMergeLayer.get() == nullptr);
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:25:27: error: ‘unique_ptr’ is not a member of ‘std’
mBboxMergeLayer = std::unique_ptr(new BboxMergeLayer());
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:25:57: error: expected primary-expression before ‘>’ token
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:30:16: error: ‘mDataRoiLayer’ was not declared in this scope
assert(mDataRoiLayer.get() == nullptr);
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:31:25: error: ‘unique_ptr’ is not a member of ‘std’
mDataRoiLayer = std::unique_ptr(new DataRoiLayer());
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:31:53: error: expected primary-expression before ‘>’ token
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:36:16: error: ‘mSelectLayer’ was not declared in this scope
assert(mSelectLayer.get() == nullptr);
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:37:24: error: ‘unique_ptr’ is not a member of ‘std’
mSelectLayer = std::unique_ptr(new RecognitionLayer(FunctionType::SELECT));
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:37:56: error: expected primary-expression before ‘>’ token
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:42:16: error: ‘mSummaryLayer’ was not declared in this scope
assert(mSummaryLayer.get() == nullptr);
/home/nvidia/liuningjie/Face-Recognition/pluginImplement.cpp:43:25: error: ‘unique_ptr’ is not a member of ‘std’
mSummaryLayer = std::unique_ptr(new RecognitionLayer(FunctionType::SUMMARY));
May I know your environment.
Have you updated any C++ library or compiler?
My environment is jetson TX2 with jetpack3.3. Gcc and g++ version is gcc(Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.11) 5.4.0 20160609.
Okay. We will try to reproduce this issue internally first.
Here is the change for JetPack3.3:
diff --git a/face-recognition/face-recognition.cpp b/face-recognition/face-recognition.cpp
index 33b5dab..da6502a 100644
--- a/face-recognition/face-recognition.cpp
+++ b/face-recognition/face-recognition.cpp
@@ -240,7 +240,7 @@ int main(int argc, char** argv)
if( display != NULL )
char str[256];
- sprintf(str, "TensorRT build %x | %4.1f FPS", NV_GIE_VERSION, display->GetFPS());
+ sprintf(str, "TensorRT build %x | %4.1f FPS", NV_TENSORRT_MAJOR, display->GetFPS());
display->SetTitle(str);
diff --git a/pluginImplement.h b/pluginImplement.h
index 8b78a0a..14a39a2 100644
--- a/pluginImplement.h
+++ b/pluginImplement.h
@@ -5,6 +5,8 @@
#include <iostream>
#include <cudnn.h>
#include <cstring>
+#include <vector>
+#include <memory>
#include "NvCaffeParser.h"
#include "NvInferPlugin.h"
I have modified the face-recognition sample as above, and it compiles well. But, why the image is inverted or upside down from the camera of Jetson TX2? And what if I want to recognize one unknown person using this sample?
You will need to re-train the detection model.
This tutorial can give you some information:
[url]https://github.com/dusty-nv/jetson-inference#locating-object-coordinates-using-detectnet[/url]
