I’m trying to add a custom layer to my architecture defined using the TensorRT API; before implementing more complicated layer I’ve been trying to add to my network the same Reshape layer as the one implemented in the sampleCharRNN sample; this results in a segmentation fault
I add the layer to network this way, and i define it as a output:
Reshape reshape(PREVIOUS_LAYER_NCHANNELS * PREVIOUS_LAYER_H * PREVIOUS_LAYER_W);
ITensor *ptr = previous_layer->getOutput(0);
auto plugin = network->addPlugin(&ptr, 1, reshape);
assert(plugin != nullptr);
plugin->setName("reshape");
plugin->getOutput(0)->setName(OUTPUT_BLOB_NAME);
network->markOutput(*plugin->getOutput(0));
the layer class implementation, and the Plugin factory implementation are as follows (same as the charRNN sample)
// Reshape plugin to feed RNN into FC layer correctly.
class Reshape : public IPlugin
public:
Reshape(size_t size) : mSize(size) {}
Reshape(const void*buf, size_t size)
assert(size == sizeof(mSize));
mSize = *static_cast<const size_t*>(buf);
int getNbOutputs() const override { return 1; }
int initialize() override { return 0; }
void terminate() override {}
size_t getWorkspaceSize(int) const override { return 0; }
int enqueue(int batchSize, const void*const * inputs, void** outputs, void* workspace, cudaStream_t stream)
CHECK(cudaMemcpyAsync(static_cast<float*>(outputs[0]),
static_cast<const float*>(inputs[0]),
sizeof(float) * mSize * batchSize, cudaMemcpyDefault, stream));
return 0;
size_t getSerializationSize() override
return sizeof(mSize);
void serialize(void* buffer) override
(*static_cast<size_t*>(buffer)) = mSize;
void configure(const Dims*, int, const Dims*, int, int) override { }
// The RNN outputs in {L, N, C}, but FC layer needs {C, 1, 1}, so we can convert RNN
// output to {L*N, C, 1, 1} and TensorRT will handle the rest.
Dims getOutputDimensions(int index, const Dims* inputs, int nbInputDims) override
assert(nbInputDims == 1);
assert(index == 0);
assert(inputs[index].nbDims == 3);
return DimsNCHW(inputs[index].d[1] * inputs[index].d[0], inputs[index].d[2], 1, 1);
private:
size_t mSize{0};
class PluginFactory : public nvinfer1::IPluginFactory
public:
// deserialization plugin implementation
IPlugin* createPlugin(const char* layerName, const void* serialData, size_t serialLength) override
assert(!strncmp(layerName, "reshape", 7));
if (!mPlugin) mPlugin = new Reshape(serialData, serialLength);
return mPlugin;
void destroyPlugin()
if (mPlugin) delete mPlugin;
mPlugin = nullptr;
private:
Reshape *mPlugin{nullptr};
}; // PluginFactory
I manage to create the engine
auto engine = builder->buildCudaEngine(*network);
but as I call the serialize method
(*modelStream) = engine->serialize();
i get a segmentation fault;
without the custom plugin the architecture compiles and works as expected;
unfortunately I cannot inspect the code of the serialize() function to see when exactly it goes wrong;
any clue of what is happening?
thanks,
f
