Sure - looking at the docs linked in the other comment, it looks like the issue on my end is possibly that I’m not running INT8 calibration (Is it expected that calibration would be required to get any results? Or does calibration simply help to produce more accurate results?).
Either way, I’ve implemented a script that would run the calibration:
lass EntropyCalibrator(trt.tensorrt.IInt8EntropyCalibrator2):
def __init__(self, input_layers, output_layers, stream):
trt.tensorrt.IInt8EntropyCalibrator2.__init__(self)
self.input_layers = input_layers
self.output_layers = output_layers
self.stream = stream
self.d_input = cuda.mem_alloc(self.stream.calibration_data.nbytes)
stream.reset()
def get_batch_size(self):
return self.stream.batch_size
def get_batch(self, bindings):
batch = self.stream.next_batch()
if not batch.size:
return None
cuda.memcpy_htod(self.d_input, batch)
bindings[0] = int(self.d_input)
return bindings
def read_calibration_cache(self):
return None
def write_calibration_cache(self, memview):
with open('calibration_cache.bin', 'wb') as f:
f.write(memview.tobytes())
return None
class ImageBatchStream():
def __init__(self, batch_size, calibration_files, preprocessor=None):
self.batch_size = batch_size
self.max_batches = (len(calibration_files) // batch_size) + \
(1 if (len(calibration_files) % batch_size) else 0)
self.files = calibration_files
self.calibration_data = np.zeros((batch_size, CHANNEL, HEIGHT, WIDTH), dtype=np.float32)
self.batch = 0
self.preprocessor = preprocessor
@staticmethod
def read_image_chw(path):
img = Image.open(path).resize((WIDTH, HEIGHT), Image.Resampling.NEAREST)
im = np.array(img, dtype=np.float32, order='C')
im = im[:,:, ::-1]
im = im.transpose((2, 0, 1))
return im
def reset(self):
self.batch = 0
def next_batch(self):
if self.batch < self.max_batches:
imgs = []
files_for_batch = self.files[self.batch_size * self.batch : self.batch_size * (self.batch + 1)]
for f in files_for_batch:
img = ImageBatchStream.read_image_chw(f)
if self.preprocessor:
img = self.preprocessor(img)
imgs.append(img)
for i in range(len(imgs)):
self.calibration_data[i] = imgs[i]
self.batch += 1
return np.ascontiguousarray(self.calibration_data, dtype=np.float32)
else:
return np.array([])
return self.batch_size
def build_engine(onnx_file_path):
# Create logger to capture errors, warnings, and other information during the build and inference phases
TRT_LOGGER = trt.Logger()
# initialize TensorRT engine and parse ONNX model
builder = trt.Builder(TRT_LOGGER)
network = builder.create_network(1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH))
parser = trt.OnnxParser(network, TRT_LOGGER)
# Create optimization profile
profile = builder.create_optimization_profile()
profile.set_shape('input', (1, 3, 224, 224), (1, 3, 224, 224), (1, 3, 224, 224))
# parse ONNX
with open(onnx_file_path, 'rb') as model:
print('Parsing ONNX file')
parser.parse(model.read())
config = builder.create_builder_config()
# Set workspace size
workspace_size = 3 # GB
config.max_workspace_size = workspace_size * 1 << 30
config.set_memory_pool_limit(trt.MemoryPoolType.WORKSPACE, workspace_size << 30)
# Create calibration
NUM_IMAGES_PER_BATCH = 1
calibration_files = create_calibration_dataset()
batchstream = ImageBatchStream(NUM_IMAGES_PER_BATCH, calibration_files)
Int8_calibrator = EntropyCalibrator(["input"], ["output"], batchstream)
# Set calibration
config.set_flag(trt.BuilderFlag.INT8)
config.int8_calibrator = Int8_calibrator
config.add_optimization_profile(profile)
# generate TensorRT engine optimized for the target platform
print('Building an engine...')
engine = builder.build_serialized_network(network, config)
print('Built an engine...')
context = engine.create_execution_context()
print("Completed creating Engine")
return engine, context
def create_calibration_dataset():
calibration_files = [os.path.join(CALIBRATION_DATASET_LOC, f) for f in os.listdir(CALIBRATION_DATASET_LOC)]
shuffle(calibration_files)
return calibration_files[:100]
def main():
print(ONNX_FILE_PATH)
onnx_model = onnx.load(ONNX_FILE_PATH)
onnx.checker.check_model(onnx_model)
engine, context = build_engine(ONNX_FILE_PATH)
The issue I’m having now is that I’m running out of memory. I’ve tried setting the workspace size and adding a swapfile, but neither of those seemed to help.
The warning logs I’m getting are:
[11/28/2022-16:17:04] [TRT] [W] Calibration Profile is not defined. Running calibration with Profile 0
[11/28/2022-16:17:05] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:34:01] [TRT] [W] Missing scale and zero-point for tensor input.416, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[11/28/2022-16:34:01] [TRT] [W] Missing scale and zero-point for tensor (Unnamed Layer* 99) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[11/28/2022-16:34:01] [TRT] [W] Missing scale and zero-point for tensor (Unnamed Layer* 100) [Matrix Multiply]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[11/28/2022-16:34:01] [TRT] [W] Missing scale and zero-point for tensor (Unnamed Layer* 101) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[11/28/2022-16:34:01] [TRT] [W] Missing scale and zero-point for tensor (Unnamed Layer* 102) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[11/28/2022-16:35:03] [TRT] [W] Tactic Device request: 204MB Available: 174MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:03] [TRT] [W] Skipping tactic 13 due to insufficient memory on requested size of 204 detected for tactic 0x0000000000000074.
[11/28/2022-16:35:03] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:05] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:05] [TRT] [W] Tactic Device request: 338MB Available: 156MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:05] [TRT] [W] Skipping tactic 13 due to insufficient memory on requested size of 338 detected for tactic 0x0000000000000074.
[11/28/2022-16:35:07] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:08] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:09] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:14] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:14] [TRT] [W] Tactic Device request: 340MB Available: 312MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:14] [TRT] [W] Skipping tactic 3 due to insufficient memory on requested size of 340 detected for tactic 0x0000000000000004.
[11/28/2022-16:35:14] [TRT] [W] Tactic Device request: 340MB Available: 311MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:14] [TRT] [W] Skipping tactic 8 due to insufficient memory on requested size of 340 detected for tactic 0x000000000000003c.
[11/28/2022-16:35:14] [TRT] [W] Tactic Device request: 340MB Available: 313MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:14] [TRT] [W] Skipping tactic 13 due to insufficient memory on requested size of 340 detected for tactic 0x0000000000000074.
[11/28/2022-16:35:16] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:16] [TRT] [W] Tactic Device request: 678MB Available: 314MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:16] [TRT] [W] Skipping tactic 3 due to insufficient memory on requested size of 678 detected for tactic 0x0000000000000004.
[11/28/2022-16:35:16] [TRT] [W] Skipping tactic 8 due to insufficient memory on requested size of 678 detected for tactic 0x000000000000003c.
[11/28/2022-16:35:16] [TRT] [W] Tactic Device request: 678MB Available: 312MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:16] [TRT] [W] Skipping tactic 13 due to insufficient memory on requested size of 678 detected for tactic 0x0000000000000074.
[11/28/2022-16:35:18] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:18] [TRT] [W] Tactic Device request: 902MB Available: 312MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:18] [TRT] [W] Skipping tactic 3 due to insufficient memory on requested size of 902 detected for tactic 0x0000000000000004.
[11/28/2022-16:35:18] [TRT] [W] Tactic Device request: 902MB Available: 313MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:18] [TRT] [W] Skipping tactic 8 due to insufficient memory on requested size of 902 detected for tactic 0x000000000000003c.
[11/28/2022-16:35:18] [TRT] [W] Skipping tactic 13 due to insufficient memory on requested size of 902 detected for tactic 0x0000000000000074.
[11/28/2022-16:35:20] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:20] [TRT] [W] Tactic Device request: 2820MB Available: 310MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:20] [TRT] [W] Skipping tactic 3 due to insufficient memory on requested size of 2820 detected for tactic 0x0000000000000004.
[11/28/2022-16:35:20] [TRT] [W] Tactic Device request: 2820MB Available: 301MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:20] [TRT] [W] Skipping tactic 8 due to insufficient memory on requested size of 2820 detected for tactic 0x000000000000003c.
[11/28/2022-16:35:20] [TRT] [W] Tactic Device request: 2820MB Available: 299MB. Device memory is insufficient to use tactic.
[11/28/2022-16:35:20] [TRT] [W] Skipping tactic 13 due to insufficient memory on requested size of 2820 detected for tactic 0x0000000000000074.
[11/28/2022-16:35:21] [TRT] [W] Unknown embedded device detected. Using 2779MiB as the allocation cap for memory on embedded devices.
[11/28/2022-16:35:23] [TRT] [W] The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
Built an engine...
AttributeError: 'tensorrt.tensorrt.IHostMemory' object has no attribute 'create_execution_context'
(I skipped a lot of the identical warning messages).
It seems like the calibration profile I’m defining may not be used here?
I get a similar set of warnings when I use trtexec, but it does complete the conversion. Is this an issue with the python API only?
