Hello, I am trying to profile a model that runs using TensorRT in order to see time spent on each layer.
However, I was not able to set up a profiler in Python. In both cases, the object does get initialized. In ConsoleProfiler case it crashes during the inference (SegFault). In Profilers case, it crashes when I use context.set_profile() method and error trace is attached below.
API Reference :: NVIDIA Deep Learning TensorRT Documentation That’s the whole relevant documentation I found.
What I tried:
inheritting from ConsoleProfiler
class MyProfiler(trt.infer.ConsoleProfiler):
def __init__(self, log_level):
super(MyProfiler, self).__init__(log_level)
def report_layer_time(layer, ms):
DOSTUFF
initializing like so
my_prof = MyProfiler(trt.infer.LogSeverity.ERROR)
context.set_profiler(my_prof)
I am getting segmentation faults when using inhereting from ConsoleProfiler.
Inheritting directly from Profiler
class MyProfiler(trt.infer.Profiler):
def __init__(self):
super(MyProfiler, self).__init__()
DOSTUFF
def __report_layer_time(layer, ms):
DOSTUFF
my_prof = MyProfiler()
In this case I get the following error:
TypeError: Swig detected a memory leak in type 'MyProfiler': no callable destructor found.
During handling of the above exception, another exception occurred:
File "benchmark.py", line 367, in <module>
tf.app.run(main=main, argv=[sys.argv[0]] + unparsed)
File "/home/justas/miniconda3/envs/batch35/lib/python3.5/site-packages/tensorflow/python/platform/app.py", line 124, in run
_sys.exit(main(argv))
File "benchmark.py", line 313, in main
prepare_benchmark(framework, model)
File "benchmark.py", line 299, in prepare_benchmark
run_inference = trt.get_inference_handle(model, FLAGS.batch_size)
SystemError: PyEval_EvalFrameEx returned a result with an error set
I tried using exit in Python to no avail.
Is it possible to do layer-by-layer profiling using TensorRT Python API?
