hello I use int8 calibrator to quantize my yolov5 model,
but get an extrem bad model performance.
mAP reduce to 1 from 50
I’m sure that my preprocess and calibration code are all right.
so Is there any tips to raise my model accuracy?
Hi @lc5104hit,
Can you please check the below link, as it may answer your query.
https://on-demand.gputechconf.com/gtc/2017/presentation/s7310-8-bit-inference-with-tensorrt.pdf
If the issue persist, request you to share the calibration cache.
hello,
I try using relu instead leakyrelu,
the result imporves.
So why this happens?
Maybe modify Leakyrelu to Relu works.
