Hi all,
I tried to transferd the TensorRT sample (sampleMNIST) in QT, but the error happen that the most error is about [undefind reference to ‘gLoginfo’ or ‘gLogger’]
the following is my main code (I just change the include method)
[code]#include “/usr/include/aarch64-linux-gnu/NvCaffeParser.h”
#include “/usr/include/aarch64-linux-gnu/NvInfer.h”
#include “common/logger.h”
#include “common/common.h”
#include “common/argsParser.h”
#include “/usr/local/cuda-10.0/targets/aarch64-linux/include/cuda_runtime_api.h”
#include
#include
#include
#include
#include
#include
#include
#include
#include
#ifdef _MSC_VER
#include <direct.h>
#else
#include <sys/stat.h>
#endif
#include
// stuff we know about the network and the input/output blobs
static const int INPUT_H = 28;
static const int INPUT_W = 28;
static const int OUTPUT_SIZE = 10;
samplesCommon::Args gArgs;
const char* INPUT_BLOB_NAME = “data”;
const char* OUTPUT_BLOB_NAME = “prob”;
using namespace nvinfer1;
using namespace nvcaffeparser1;
const std::string gSampleName = “TensorRT.sample_mnist_api”;
// Load weights from files shared with TensorRT samples.
// TensorRT weight files have a simple space delimited format:
// [type]
std::map<std::string, Weights> loadWeights(const std::string file)
gLogInfo << "Loading weights: " << file << std::endl;
std::map<std::string, Weights> weightMap;
// Open weights file
std::ifstream input(file);
assert(input.is_open() && "Unable to load weight file.");
// Read number of weight blobs
int32_t count;
input >> count;
assert(count > 0 && "Invalid weight map file.");
while (count--)
Weights wt{DataType::kFLOAT, nullptr, 0};
uint32_t type, size;
// Read name and type of blob
std::string name;
input >> name >> std::dec >> type >> size;
wt.type = static_cast<DataType>(type);
// Load blob
if (wt.type == DataType::kFLOAT)
uint32_t* val = reinterpret_cast<uint32_t*>(malloc(sizeof(val) * size));
for (uint32_t x = 0, y = size; x < y; ++x)
input >> std::hex >> val[x];
wt.values = val;
else if (wt.type == DataType::kHALF)
uint16_t* val = reinterpret_cast<uint16_t*>(malloc(sizeof(val) * size));
wt.values = val;
wt.count = size;
weightMap[name] = wt;
return weightMap;
// simple PGM (portable greyscale map) reader
void readPGMFile(const std::string& filename, uint8_t buffer[INPUT_H * INPUT_W])
readPGMFile(locateFile(filename, gArgs.dataDirs), buffer, INPUT_H, INPUT_W);
// Creat the engine using only the API and not any parser.
ICudaEngine* createMNISTEngine(unsigned int maxBatchSize, IBuilder* builder, DataType dt)
INetworkDefinition* network = builder->createNetwork();
// Create input tensor of shape { 1, 1, 28, 28 } with name INPUT_BLOB_NAME
ITensor* data = network->addInput(INPUT_BLOB_NAME, dt, Dims3{1, INPUT_H, INPUT_W});
assert(data);
// Create scale layer with default power/shift and specified scale parameter.
const float scaleParam = 0.0125f;
const Weights power{DataType::kFLOAT, nullptr, 0};
const Weights shift{DataType::kFLOAT, nullptr, 0};
const Weights scale{DataType::kFLOAT, &scaleParam, 1};
IScaleLayer* scale_1 = network->addScale(*data, ScaleMode::kUNIFORM, shift, scale, power);
assert(scale_1);
// Add convolution layer with 20 outputs and a 5x5 filter.
std::map<std::string, Weights> weightMap = loadWeights(locateFile("mnistapi.wts", gArgs.dataDirs));
IConvolutionLayer* conv1 = network->addConvolution(*scale_1->getOutput(0), 20, DimsHW{5, 5}, weightMap["conv1filter"], weightMap["conv1bias"]);
assert(conv1);
conv1->setStride(DimsHW{1, 1});
// Add max pooling layer with stride of 2x2 and kernel size of 2x2.
IPoolingLayer* pool1 = network->addPooling(*conv1->getOutput(0), PoolingType::kMAX, DimsHW{2, 2});
assert(pool1);
pool1->setStride(DimsHW{2, 2});
// Add second convolution layer with 50 outputs and a 5x5 filter.
IConvolutionLayer* conv2 = network->addConvolution(*pool1->getOutput(0), 50, DimsHW{5, 5}, weightMap["conv2filter"], weightMap["conv2bias"]);
assert(conv2);
conv2->setStride(DimsHW{1, 1});
// Add second max pooling layer with stride of 2x2 and kernel size of 2x2
IPoolingLayer* pool2 = network->addPooling(*conv2->getOutput(0), PoolingType::kMAX, DimsHW{2, 2});
assert(pool2);
pool2->setStride(DimsHW{2, 2});
// Add fully connected layer with 500 outputs.
IFullyConnectedLayer* ip1 = network->addFullyConnected(*pool2->getOutput(0), 500, weightMap["ip1filter"], weightMap["ip1bias"]);
assert(ip1);
// Add activation layer using the ReLU algorithm.
IActivationLayer* relu1 = network->addActivation(*ip1->getOutput(0), ActivationType::kRELU);
assert(relu1);
// Add second fully connected layer with 10 outputs.
IFullyConnectedLayer* ip2 = network->addFullyConnected(*relu1->getOutput(0), OUTPUT_SIZE, weightMap["ip2filter"], weightMap["ip2bias"]);
assert(ip2);
// Add softmax layer to determine the probability.
ISoftMaxLayer* prob = network->addSoftMax(*ip2->getOutput(0));
assert(prob);
prob->getOutput(0)->setName(OUTPUT_BLOB_NAME);
network->markOutput(*prob->getOutput(0));
// Build engine
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(1 << 20);
builder->setFp16Mode(gArgs.runInFp16);
if (gArgs.runInInt8)
samplesCommon::setAllTensorScales(network, 127.0f, 127.0f);
samplesCommon::enableDLA(builder, gArgs.useDLACore);
ICudaEngine* engine = builder->buildCudaEngine(*network);
// Don't need the network any more
network->destroy();
// Release host memory
for (auto& mem : weightMap)
free((void*) (mem.second.values));
return engine;
void APIToModel(unsigned int maxBatchSize, IHostMemory** modelStream)
// Create builder
IBuilder* builder = createInferBuilder(gLogger.getTRTLogger());
assert(builder != nullptr);
// Create model to populate the network, then set the outputs and create an engine
ICudaEngine* engine = createMNISTEngine(maxBatchSize, builder, DataType::kFLOAT);
assert(engine != nullptr);
// Serialize the engine
(*modelStream) = engine->serialize();
// Close everything down
engine->destroy();
builder->destroy();
void doInference(IExecutionContext& context, float* input, float* output, int batchSize)
const ICudaEngine& engine = context.getEngine();
// Pointers to input and output device buffers to pass to engine.
// Engine requires exactly IEngine::getNbBindings() number of buffers.
assert(engine.getNbBindings() == 2);
void* buffers[2];
// In order to bind the buffers, we need to know the names of the input and output tensors.
// Note that indices are guaranteed to be less than IEngine::getNbBindings()
const int inputIndex = engine.getBindingIndex(INPUT_BLOB_NAME);
const int outputIndex = engine.getBindingIndex(OUTPUT_BLOB_NAME);
// Create GPU buffers on device
CHECK(cudaMalloc(&buffers[inputIndex], batchSize * INPUT_H * INPUT_W * sizeof(float)));
CHECK(cudaMalloc(&buffers[outputIndex], batchSize * OUTPUT_SIZE * sizeof(float)));
// Create stream
cudaStream_t stream;
CHECK(cudaStreamCreate(&stream));
// DMA input batch data to device, infer on the batch asynchronously, and DMA output back to host
CHECK(cudaMemcpyAsync(buffers[inputIndex], input, batchSize * INPUT_H * INPUT_W * sizeof(float), cudaMemcpyHostToDevice, stream));
context.enqueue(batchSize, buffers, stream, nullptr);
CHECK(cudaMemcpyAsync(output, buffers[outputIndex], batchSize * OUTPUT_SIZE * sizeof(float), cudaMemcpyDeviceToHost, stream));
cudaStreamSynchronize(stream);
// Release stream and buffers
cudaStreamDestroy(stream);
CHECK(cudaFree(buffers[inputIndex]));
CHECK(cudaFree(buffers[outputIndex]));
//! \brief This function prints the help information for running this sample
void printHelpInfo()
std::cout << “Usage: ./sample_mnist_api [-h or --help] [-d or --datadir=] [–useDLACore=]\n”;
std::cout << “–help Display help information\n”;
std::cout << “–datadir Specify path to a data directory, overriding the default. This option can be used multiple times to add multiple directories. If no data directories are given, the default is to use (data/samples/mnist/, data/mnist/)” << std::endl;
std::cout << “–useDLACore=N Specify a DLA engine for layers that support DLA. Value can range from 0 to n-1, where n is the number of DLA engines on the platform.” << std::endl;
std::cout << “–int8 Run in Int8 mode.\n”;
std::cout << “–fp16 Run in FP16 mode.\n”;
int main(int argc, char** argv)
bool argsOK = samplesCommon::parseArgs(gArgs, argc, argv);
if (gArgs.help)
printHelpInfo();
return EXIT_SUCCESS;
if (!argsOK)
gLogError << “Invalid arguments” << std::endl;
printHelpInfo();
return EXIT_FAILURE;
if (gArgs.dataDirs.empty())
gArgs.dataDirs = std::vectorstd::string{“data/samples/mnist/”, “data/mnist/”};
auto sampleTest = gLogger.defineTest(gSampleName, argc, const_cast<const char**>(argv));
gLogger.reportTestStart(sampleTest);
// create a model using the API directly and serialize it to a stream
IHostMemory* modelStream{nullptr};
APIToModel(1, &modelStream);
assert(modelStream != nullptr);
// Read random digit file
srand(unsigned(time(nullptr)));
uint8_t fileData[INPUT_H * INPUT_W];
const int num = rand() % 10;
readPGMFile(std::to_string(num) + ".pgm", fileData);
// Print ASCII representation of digit image
gLogInfo << "Input:\n";
for (int i = 0; i < INPUT_H * INPUT_W; i++)
gLogInfo << (" .:-=+*#%@"[fileData[i] / 26]) << (((i + 1) % INPUT_W) ? "" : "\n");
gLogInfo << std::endl;
// Parse mean file
ICaffeParser* parser = createCaffeParser();
assert(parser != nullptr);
IBinaryProtoBlob* meanBlob = parser->parseBinaryProto(locateFile("mnist_mean.binaryproto", gArgs.dataDirs).c_str());
parser->destroy();
const float* meanData = reinterpret_cast<const float*>(meanBlob->getData());
// Subtract mean from image
float data[INPUT_H * INPUT_W];
data[i] = float(fileData[i]) - meanData[i];
meanBlob->destroy();
IRuntime* runtime = createInferRuntime(gLogger.getTRTLogger());
assert(runtime != nullptr);
if (gArgs.useDLACore >= 0)
runtime->setDLACore(gArgs.useDLACore);
ICudaEngine* engine = runtime->deserializeCudaEngine(modelStream->data(), modelStream->size(), nullptr);
modelStream->destroy();
IExecutionContext* context = engine->createExecutionContext();
assert(context != nullptr);
// Run inference
float prob[OUTPUT_SIZE];
doInference(*context, data, prob, 1);
// Destroy the engine
context->destroy();
engine->destroy();
runtime->destroy();
// Print histogram of the output distribution
gLogInfo << "Output:\n";
float val{0.0f};
int idx{0};
for (unsigned int i = 0; i < 10; i++)
val = std::max(val, prob[i]);
if (val == prob[i])
idx = i;
gLogInfo << i << ": " << std::string(int(std::floor(prob[i] * 10 + 0.5f)), '*') << "\n";
bool pass{idx == num && val > 0.9f};
return gLogger.reportTest(sampleTest, pass);
[code]
and the .pro file:
[code]TEMPLATE = app
CONFIG += console c++11
CONFIG -= app_bundle
CONFIG -= qt
#sample make file
INCLUDEPATH += $$CUDA_DIR/include
INCLUDEPATH += /usr/local/include
INCLUDEPATH += usr/local/cuda-10.0/targets/aarch64-linux/lib
INCLUDEPATH += usr/local/cuda-10.0/targets/aarch64-linux/include
#fro, Nv talk
INCLUDEPATH += /usr/include/aarch64-linux-gnu
LIBS += -L/usr/lib/aarch64-linux-gnu -lnvinfer -lnvparsers -lnvinfer_plugin ##
LIBS += -L/usr/local/cuda-10.0/targets/aarch64-linux/lib -lcudart ##
#LIBS += -L/usr/local/cuda-10.0/targets/aarch64-linux/include/cuda_runtime_api.h
SOURCES += main.cpp
[code]
the total erroe report is:
[code]
/home/nvidia/wworkspace/Qt/build-trt_test-Desktop-Debug/main.o:-1: In function loadWeights(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)': /home/nvidia/wworkspace/Qt/trt_test/main.cpp:43: error: undefined reference to
gLogInfo’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:43: error: undefined reference to gLogInfo' /home/nvidia/wworkspace/Qt/build-trt_test-Desktop-Debug/main.o:-1: In function
APIToModel(unsigned int, nvinfer1::IHostMemory**)‘:
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:182: error: undefined reference to gLogger' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:182: error: undefined reference to
gLogger’
/home/nvidia/wworkspace/Qt/build-trt_test-Desktop-Debug/main.o:-1: In function main': /home/nvidia/wworkspace/Qt/trt_test/main.cpp:255: error: undefined reference to
gLogError’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:280: error: undefined reference to gLogInfo' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:280: error: undefined reference to
gLogInfo’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:282: error: undefined reference to gLogInfo' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:283: error: undefined reference to
gLogInfo’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:283: error: more undefined references to gLogInfo' follow /home/nvidia/wworkspace/Qt/build-trt_test-Desktop-Debug/main.o:-1: In function
main’:
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:300: error: undefined reference to gLogger' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:300: error: undefined reference to
gLogger’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:322: error: undefined reference to gLogInfo' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:322: error: undefined reference to
gLogInfo’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:330: error: undefined reference to gLogInfo' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:330: error: undefined reference to
gLogInfo’
/home/nvidia/wworkspace/Qt/trt_test/main.cpp:332: error: undefined reference to gLogInfo' /home/nvidia/wworkspace/Qt/trt_test/main.cpp:332: error: undefined reference to
gLogInfo’
:-1: error: collect2: error: ld returned 1 exit status
[code]
I have no idea there the gLog LIB come from and confuse that its run well sample on originaly Makefile, THX.
