TensorRT UFF parser warning keepdims is ignored by the UFF Parser and defaults to True
I am working on TensorRT 5.0.2.6 and I am converting my model to uff format. I am able to convert the model with warning message as “keepdims is ignored by the UFF Parser and defaults to True”. When I try to run inference using C++ API, at runtime I get the error as “add_1/add: elementwise inputs must have same dimensions or follow broadcast rules (input dimensions were [13,20,31] and [13,20,30])”.
I am aware that all the warning from uff converter can not be ignored. But I would like to know how to resolve this issue ?
(Note: I use Transpose convolution layers in the model)
I am facing the same issue. I am using a Resnet implementation provided here: GitHub - raghakot/keras-resnet: Residual networks implementation using Keras-1.0 functional API
Tensorflow version:1.14.0
Keras version: 2.2.4
Tensorrt version: 5.1.5.0
I am using older version of tensorflow for legacy reasons.
Your help is appreciated.
