Does tf.layers.batch_normalization() support by the operation “FusedBatchNorm”?
When I used this function in my model and convert it to .uff file, I got some warnings: No conversion function registered for the layer: Merge (and Switch) yet.
Is the tf.layers.batch_normalization() function including these three operation “FusedBatchNorm”, “Merge”, “Switch”, but only “FusedBatchNorm” supported by TensorRT?
Recommend the option to implement a plugin layer for the unsupported operation or modify the original network to remove this operation. Could try using graphsurgeon for this.
