The hidden interface is just avaliable for int8 with calibrator on fixed input size.
You didn’t test it for dynamic input size and just place on the guider page ?
Can you provide the following information so we can better help?
Files
Include any logs, source, models (.uff, .pb, etc.) that would be helpful to diagnose the problem.
If relevant, please include the full traceback.
Reproducibility
Please provide a minimal test case that reproduces your error.
Ubuntu16.04
P40
396.26
9.0
7.6.3
3.6.8
1.12
6.0.1.5
class MyCalibrator(trt.IInt8EntropyCalibrator2):
def __init__(self, engine8_path, num_of_samples):
trt.IInt8EntropyCalibrator2.__init__(self)
self.num_of_samples = num_of_samples
self.device_dict = dict()
self.load_a_batch = self.get_a_batch()
basename = os.path.basename(engine8_path)
self.cache_file = f'{CACHE_FOLDER}/{basename}.cache_{num_of_samples}'
def copy_data(self, data):
if data.shape not in self.device_dict:
nbytes = data.size * trt.float32.itemsize
self.device_dict[data.shape] = cuda.mem_alloc(nbytes)
cuda.memcpy_htod(self.device_dict[data.shape], data)
return int(self.device_dict[data.shape])
def get_a_batch(self):
count = 0
for line in open(IMAGE8_PATH):
path = line.strip()
path = os.path.join(IMAGE8_DIR, path)
data = read_image(path)
device_id = self.copy_data(data)
count += 1
print(f'[{"%06d"%count}] Reading {path} ok ...')
yield [device_id]
if count >= self.num_of_samples: break
def get_batch(self, *names):
try:
return next(self.load_a_batch)
except StopIteration:
return None
def get_batch_size(self):
return 1
def read_calibration_cache(self):
if os.path.exists(self.cache_file):
with open(self.cache_file, "rb") as f:
return f.read()
def write_calibration_cache(self, cache):
with open(self.cache_file, "wb") as f:
f.write(cache)
def build_engine8(weights, calibrator):
flag = 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
with trt.Builder(TRT_LOGGER) as builder, \
builder.create_network(flag) as network, \
builder.create_builder_config() as config:
get_network(ModelData, network, weights)
builder.max_batch_size = calibrator.get_batch_size()
builder.max_workspace_size = common.GiB(100)
config.int8_calibrator = calibrator
config.set_flag(trt.BuilderFlag.INT8)
config.set_flag(trt.BuilderFlag.STRICT_TYPES)
profile = builder.create_optimization_profile()
profile.set_shape(
ModelData.INPUT_NAME,
ModelData.MIN_INPUT_SHAPE,
ModelData.OPT_INPUT_SHAPE,
ModelData.MAX_INPUT_SHAPE)
config.add_optimization_profile(profile)
# print(config.get_flag(trt.BuilderFlag.INT8))
# print(config.get_flag(trt.BuilderFlag.STRICT_TYPES))
return builder.build_engine(network, config)
Using the above code to quantize a model, error occurs as follows.
[TensorRT] WARNING: Explicit batch network detected and batch size specified, use execute without batch size instead.
[TensorRT] ERROR: Parameter check failed at: engine.cpp::resolveSlots::1024, condition: allInputDimensionsSpecified(routine)
I think the problem is that, the internal calibrating API in building_cuda_engine isn’t designed for dynamic input size, since there is no interface for the custom calibrator to control the process of feeding data to the calibrator but just return a batch data. So the user can’t set the bindingShape, and finally a allInputDimensionsSpecified
error occurs.
I think the trt.IInt8EntropyCalibrator2.get_batch
function should provide another arg as context, for the user to do context.set_binding_shape(0, data.shape)
, and the problem would be solved.
And the internal calibrating process seems to used the deprecated enqueue
function but not the enqueueV2
, since WARNING: Explicit batch network detected and batch size specified, use execute without batch size instead.
Maybe this number too big?
Hi yfjiaren,
I’m not sure what input shapes you’re using here:
profile.set_shape(
But I see this in the docs, specifically for int8: https://docs.nvidia.com/deeplearning/sdk/tensorrt-archived/tensorrt-601/tensorrt-developer-guide/index.html#rest_dynamic_shapes
“Int8 requires that the channel dimension be a build-time constant.”
Perhaps your channel dimension is dynamic, and that isn’t allowed for Int8?
class ModelData:
MIN_BATCH = 1
OPT_BATCH = 1
MAX_BATCH = 8
BLOCK_SIZE = 8
FIX_HEIGHT = 48
MIN_WIDTH = 48
OPT_WIDTH = 480
MAX_WIDTH = 1200
INPUT_NAME = "input"
INPUT_DTYPE = trt.float32
INPUT_SHAPE = (-1, 1, FIX_HEIGHT, -1)
OUTPUT_NAME = "output"
OUTPUT_SHAPE = (-1, -1, 21502)
MIN_INPUT_SHAPE = (MIN_BATCH, 1, FIX_HEIGHT, MIN_WIDTH)
OPT_INPUT_SHAPE = (OPT_BATCH, 1, FIX_HEIGHT, OPT_WIDTH)
MAX_INPUT_SHAPE = (MAX_BATCH, 1, FIX_HEIGHT, MAX_WIDTH)
This is the definition of ModelData class.
Hi yfjiaren,
Does this error still occur for you in TensorRT 7? If so, can you share a sample dynamic shape ONNX model for me to play around with?
However, just FYI there is a separate issue with ONNX + INT8 calibration being tracked here that may affect you: https://github.com/NVIDIA/TensorRT/issues/289. The issue was just fixed internally, not sure when it will be available yet.
Yes, the problem still exists in version 7.0.0.11 …
Hi, I have the same problem in version 7.0.0.11, and is there any way to solve this except the upgraded version ?
Hi, Please refer to the below links to perform inference in INT8
Hi, I have already read about that and run the sample successfully, but the model in this sample is fixed input size. I want to know how to perform inference in INT8 on dynamic input size model with TensorRT 7.0.0.11, it always got errors like above.
I also found if my onnx model is dynamic input, I can’t do INT8 calibration.
My platform:
ubuntu 18.04
jetson NX
Python 3.6.9
tensorrt7.1.3.0-1+cuda10.2
Hi, This release note 7.0.0 offers the solution and it worked. You can refer to this release note, it seems to be fixed in version 7.1.3.
