TensorRTOptimizer warning: TensorRTOptimizer is probably called on funcdef! This optimizer must *NOT...
I got this warning everytime when I optimize a tensorflow graph:
TensorRTOptimizer is probably called on funcdef! This optimizer must *NOT* be called on function objects.
I just want to understand what this warning means, how can I avoid it and what its impact.
I am using tensorRT 5.1.5 with cuda 10.0 and tensorflow-gpu 1.15
It’s safe to ignore this warning.
The warning message has been improved a little bit in TF 2.1, but it’s still there.
Here is what happens in a nutshell:
We name the input graph tf_graph and then call TF grappler on the input. Then grappler runs the TRT optimization pass on multiple objects that are available in the input (including tf_graph).
TF-TRT checks internally what object is being used and only continues with the optimization if the object name is tf_graph and otherwise prints a warning message and returns.
