I am getting this error while converting a finetuned model only, when i am just using a pretrained model its working fine.
2021-11-04 16:06:55.345573: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.349826: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.350105: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.350528: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2 FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2021-11-04 16:06:55.350809: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.351071: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.351302: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.766650: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.766916: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.767136: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-11-04 16:06:55.767349: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1510] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 2440 MB memory: → device: 0, name: GeForce GTX 1650, pci bus id: 0000:01:00.0, compute capability: 7.5
File “scripts/convert_saved_model_trt_engine.py”, line 20, in
converter.convert()
File “/home/hexa/miniconda3/envs/TRT/lib/python3.8/site-packages/tensorflow/python/compiler/tensorrt/trt_convert.py”, line 1096, in convert
self._saved_model = load.load(self._input_saved_model_dir,
File “/home/hexa/miniconda3/envs/TRT/lib/python3.8/site-packages/tensorflow/python/saved_model/load.py”, line 864, in load
result = load_internal(export_dir, tags, options)[“root”]
File “/home/hexa/miniconda3/envs/TRT/lib/python3.8/site-packages/tensorflow/python/saved_model/load.py”, line 902, in load_internal
loader = loader_cls(object_graph_proto, saved_model_proto, export_dir,
File “/home/hexa/miniconda3/envs/TRT/lib/python3.8/site-packages/tensorflow/python/saved_model/load.py”, line 162, in init
self._load_all()
File “/home/hexa/miniconda3/envs/TRT/lib/python3.8/site-packages/tensorflow/python/saved_model/load.py”, line 259, in _load_all
self._load_nodes()
File “/home/hexa/miniconda3/envs/TRT/lib/python3.8/site-packages/tensorflow/python/saved_model/load.py”, line 448, in _load_nodes
slot_variable = optimizer_object.add_slot(
AttributeError: ‘_UserObject’ object has no attribute ‘add_slot’
This is the code I am using to convert to tensorrt:
import tensorflow as tf
params = tf.experimental.tensorrt.ConversionParams(
precision_mode='FP32')
converter = tf.experimental.tensorrt.Converter(
input_saved_model_dir="saved_models", conversion_params=params)
converter.convert()
converter.save(output_saved_model_dir="trt_model_FP32")
Above code work when the pretrained model is not modified. But when change the last layer for my custom data the model saved gave error. This is how I modifying last layer to predict 2 claases.
model = ResNet50(include_top=False, weights="imagenet")
inputs = tf.keras.Input(shape=(128, 128, 3))
output = model(inputs)
output = tf.keras.layers.GlobalAveragePooling2D()(output)
output = tf.keras.layers.Dense(2)(output)
model = tf.keras.Model(inputs, output)
model.save('saved_models')
Machine specfications are below:
OS: Ubuntu-18.04
Cuda: 10.2, Cudnn: 7.6.5.32
Tensorflow: 2.6
Tensorrt: 7.2.3.4
