The Terasic FPGA HDL appears to be very incomplete in the repository and only contains a few top level files. Is there a repository somewhere else that has a file set that is buildable under Quartus Prime Pro to make an FPGA bitstream.
phil2
1
The Terasic FPGA HDL in the repo is meant as example code demonstrating how one can instantiate and use the Hololink IP in the Stratix 10 FPGA, not a fully realizable design. Please see Altera’s site for more information as well as link to access the full reference design: Sensor Interfaces for FPGAs
Related topics
| Newest Sensor Bridge FPGA IP Location | 2 | 124 | March 20, 2026 | |
| Holoscan Sensor Bridge FPGA IP, Compilation Order | 1 | 131 | November 19, 2025 | |
| Missing file from 2510 HSB FPGA IP | 1 | 79 | June 2, 2026 | |
| Missing files from 2510 HSB IP? | 0 | 39 | May 15, 2026 | |
| Release date for FPGA Holoscan Sensor Bridge IP version 2501 or later | 3 | 142 | January 12, 2026 | |
| Holoscan Sensor Bridge FPGA IP, Sensor TX (FPGA to Sensor) Support | 2 | 152 | November 4, 2025 | |
| Bandwidth limitations of Holoscan Sensor Bridge for high-throughput sensor data (≈100 Gbps) | 3 | 412 | November 7, 2025 | |
| Thor jp7.1 lattice hsb with imx274. "Unable to deserialize bootp request vendor data." | 1 | 105 | February 22, 2026 | |
| Holoscan-sensor-bridge does not work with the MPF200-ETH-Sensor-Bridge | 4 | 150 | January 4, 2026 | |
| Holoscan sensor bridge FPGA firmware update failure | 10 | 146 | April 16, 2026 |
