Tesla c2050 problems
I had a c1060 along with my 8800GTX in my workstation and everything worked fine.
Now I have moved the c1060 to another computer and replaced it with a c2050, the problems have arrived.
Driver 257.21 does not see the new Tesla and driver 197.68 does not see the 8800GTX.
Around and around I go… reinstalling everything several times to no avail.
What can I do?
Problem solved…
After using drive sweeper over and over after trying different drivers I final got it to work.
It seems that having one of my monitors on the c2050 was throwing things off also.
Problem solved…
I am having trouble with my c2050 as well. Did you get a monitor to run on it? I can’t get any output from the DVI port. What driver did you end up using?
thanks
