Hi, I am moving my first steps into CUDA by using my old laptop’s GeForce 610M. I have written a couple of functions involving cublasDSYMM and on my laptop the comparison between GPU vs CPU implementation gave no such big speed improvements. Since I have the possibility to run code on an Azure’s VM, specifically the NC6, endowed with a Tesla K80, I was puzzled in seeing that execution time on the GPU implementation on the K80 was way slower than on the GeForce 610M (roughly 5secs vs 1 sec - matrix size 1600). My first thought was that this could be due to my poor ability of coding, so I have measured the execution time of deviceQuery on both machines: the picture did not change. My impression is that there is a big “latency” on the VM and don’t know why. Do you have some suggestions in order to understand why the K80 on the VM is performing so poorly?
Here are some outputs from the VM
Please note that I have resized the VM in order to see if something would have changed with a better GPU, regrettably no good news. The outputs below refer to a Tesla P100
nvidia-smi
Wed Jun 5 13:09:41 2019
| NVIDIA-SMI 410.104 Driver Version: 410.104 CUDA Version: 10.0 |
| 0 Tesla P100-PCIE... Off | 000036B6:00:00.0 Off | 0 |
| N/A 26C P0 25W / 250W | 0MiB / 16280MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Tesla P100-PCIE-16GB"
CUDA Driver Version / Runtime Version 10.0 / 9.0
CUDA Capability Major/Minor version number: 6.0
Total amount of global memory: 16281 MBytes (17071734784 bytes)
(56) Multiprocessors, ( 64) CUDA Cores/MP: 3584 CUDA Cores
GPU Max Clock rate: 1329 MHz (1.33 GHz)
Memory Clock rate: 715 Mhz
Memory Bus Width: 4096-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Enabled
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 14006 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.0, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
And to show how long does it take to run deviceQuery
time ./deviceQuery > /dev/null
real 0m1.040s
user 0m0.004s
sys 0m0.942s
1 second is just unacceptable, don’t you think so?
