Hi all,
Our group just installed a Tesla S1070 on a Linux-64 bit operation system. I run the example “deviceQuery” in SDK package and found there are only 2 GPUs detected.
Here is the message:
Device 0: “Tesla T10 Processor”
Major revision number: 1
Minor revision number: 3
Total amount of global memory: 4294705152 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.30 GHz
Concurrent copy and execution: Yes
Device 1: “Tesla T10 Processor”
Warp size: 32
Test PASSED
Press ENTER to exit…
I thought Tesla S1070 had 4 GPUs, why I only saw 2? Is there something wrong with my hardware connections? Thanks for any advise.
Xuejun
