• Issue Type( questions)
GPU : Tesla-T4 * 2
Deepstream : 5.1-21.02-devel
TensorRT version : 7.2.2-1 + cuda 11.1
NVIDIA GPU Driver : 470.86
I know Tesla T4 GPU is for computing unit , not for display
But in my project, I have to check the result of the inferrence in real-time.
so using fakesink cannot help me.
6 months ago, I found 5-a in the following link and solved the problem with this
(Deepstream/FAQ - eLinux.org)
Last week, my server got some trouble so I reinstall ubuntu 20.04 LTS, and NVIDIA driver, Deepstream Docker just like before.
But this time I cannot run my deepstream project like last time (Of course, I can use fakesink to run my project but this doesn’t solve my problem)
This is error message I got
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
If I modify xorg.conf for using GPU for display render(virtual display) and reboot, using GUI impossible (just blackscreen)
If I look at the command nvidia-smi in CLI, I can check No.1 GPU using memory for display (about 100MB)
What do I have to do??
Please give me some advice.
Below are the commands ,logs, and nvidia-bug-report.log
nvidia-bug-report.log.gz (1.2 MB)
sudo nvidia-xconfig --query-gpu-info
and result
Number of GPUs: 2
GPU #0:
UUID : GPU-37f78b2a-4ed1-2949-87b8-a48ba164b072
PCI BusID : PCI:59:0:0
Number of Display Devices: 0
GPU #1:
UUID : GPU-a6359d4f-b664-c1c9-ec85-2193a9d523af
PCI BusID : PCI:134:0:0
sudo nvidia-xconfig --busid=PCI:134:0:0 --allow-empty-initial-configuration
WARNING: Unable to locate/open X configuration file.
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xorg-server' found
Option "AllowEmptyInitialConfiguration" "True" added to Screen "Screen0".
New X configuration file written to '/etc/X11/xorg.conf'
Here is my xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 470.86
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:134:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
