Hi guys!
I got 4 T4 and I want to offer their power to my colleagues using K8s and Docker. My boss said, that all the cool kids are using it, and that’s why we’re gonna start using it, because we are pretty cool as well.
I got K8s running and followed the instructions from here. However, I ran into some problems with the Dockerfile. So I copied the Dockerfile from
/home/ubuntu/driver/ubuntu20.04/Dockerfile
to my home directory /home/ubuntu/ (I am on Ubuntu 20.04). Therefore, I had to modify the Dockerfile. Now, it looks like this:
FROM ubuntu:20.04 as build
RUN echo ‘debconf debconf/frontend select Noninteractive’ | debconf-set-selections
RUN apt-get update && apt-get install -y --no-install-recommends
apt-utils
build-essential
ca-certificates
curl
git &&
rm -rf /var/lib/apt/lists/*ENV GOLANG_VERSION 1.15.5
RUN curl -fsSL https://storage.googleapis.com/golang/go${GOLANG_VERSION}.linux-amd64.tar.gz
| tar -C /usr/local -xz
ENV PATH /usr/local/go/bin:$PATHWORKDIR /work
RUN git clone nvidia / container-images / driver · GitLab &&
cd driver/vgpu/src &&
go build -o vgpu-util &&
mv vgpu-util /workFROM nvidia/cuda:11.4.1-base-ubuntu20.04
ARG BASE_URL=http://us.download.nvidia.com/XFree86/Linux-x86_64
ARG BASE_URL=https://us.download.nvidia.com/tesla
ARG DRIVER_VERSION
ENV DRIVER_VERSION=$DRIVER_VERSION
ENV DEBIAN_FRONTEND=noninteractive#Arg to indicate if driver type is either of passthrough(baremetal) or vgpu
ARG DRIVER_TYPE=passthrough
ENV DRIVER_TYPE=$DRIVER_TYPE
ARG DRIVER_BRANCH=460
ENV DRIVER_BRANCH=$DRIVER_BRANCH
ARG VGPU_LICENSE_SERVER_TYPE=FNE
ENV VGPU_LICENSE_SERVER_TYPE=$VGPU_LICENSE_SERVER_TYPE
enable vGPU version compability check by default
ARG DISABLE_VGPU_VERSION_CHECK=false
ENV DISABLE_VGPU_VERSION_CHECK=$DISABLE_VGPU_VERSION_CHECK
ENV NVIDIA_VISIBLE_DEVICES=voidRUN echo ‘debconf debconf/frontend select Noninteractive’ | debconf-set-selections
RUN dpkg --add-architecture i386 &&
apt-utils
build-essential
ca-certificates
curl
kmod
file
libelf-dev
libglvnd-dev
pkg-config &&
rm -rf /var/lib/apt/lists/*RUN echo “deb [arch=amd64] Index of /ubuntu focal main universe” > /etc/apt/sources.list &&
echo “deb [arch=amd64] Index of /ubuntu focal-updates main universe” >> /etc/apt/sources.list &&
echo “deb [arch=amd64] Index of /ubuntu focal-security main universe” >> /etc/apt/sources.list &&
usermod -o -u 0 -g 0 _aptRUN curl -fsSL -o /usr/local/bin/donkey https://github.com/3XX0/donkey/releases/download/v1.1.0/donkey &&
chmod +x /usr/local/bin/donkeyChanges made in the next line:
COPY ./driver/ubuntu20.04/nvidia-driver/ /usr/local/bin
COPY --from=build /work/vgpu-util /usr/local/bin
The next three lines were changed as well
ADD ./driver/ubuntu20.04/drivers/NVIDIA-Linux-x86_64-470.63.01-grid.run drivers/
ADD ./driver/ubuntu20.04/drivers/README.md drivers/
ADD ./driver/ubuntu20.04/drivers/vgpuDriverCatalog.yaml drivers/#Fetch the installer automatically for passthrough/baremetal types
RUN if [ “$DRIVER_TYPE” != “vgpu” ]; then
cd drivers &&
curl -fSsl -O $BASE_URL/$DRIVER_VERSION/NVIDIA-Linux-x86_64-$DRIVER_VERSION.run &&
chmod +x NVIDIA-Linux-x86_64-$DRIVER_VERSION.run &&
apt-get update &&
apt-get install -y --no-install-recommends nvidia-fabricmanager-${DRIVER_BRANCH}=${DRIVER_VERSION}-1
libnvidia-nscq-${DRIVER_BRANCH}=${DRIVER_VERSION}-1; fiWORKDIR /drivers
ARG PUBLIC_KEY=empty
COPY ${PUBLIC_KEY} kernel/pubkey.x509ENTRYPOINT [“nvidia-driver”, “init”]
This file runs when I employ
sudo docker build --build-arg DRIVER_TYPE=vgpu --build-arg DRIVER_VERSION=$VGPU_DRIVER_VERSION -t ${PRIVATE_REGISTRY}/driver:${VERSION}-${OS_TAG} .
where I set the variables starting with $ as you suggested here. However, it breaks in step 35 where
is to be executed. Can you guys give me a hint how fix this? The error message reads
Step 35/36 : COPY ${PUBLIC_KEY} kernel/pubkey.x509
COPY failed: file not found in build context or excluded by .dockerignore: stat empty: file does not exist
Please note, that my Dockerfile is located at
/home/ubuntu/Dockerfile
Thanks in advance,
Robert
