Tesla V100-PCIE-32GB detected as V100-SXM2-32GB on Windows (Code 10, driver won’t start)
I’m having an issue with an NVIDIA Tesla V100 GPU in a Windows workstation, where the installed card is labeled as a PCIe model but Windows identifies it as an SXM2 model, causing the driver to fail to start.
System Information
  • Workstation: HP Z2 Tower G9 Workstation
  • Operating System: Windows
  • GPU (physical label on card): NVIDIA Tesla V100-PCIE-32GB
  • Serial Number (printed on card): 1563320004976
Issue Description
The physical GPU installed in the PCIe slot is clearly labeled Tesla V100-PCIE-32GB on the card itself.
However, after installing NVIDIA data center drivers, Windows identifies the device as:
NVIDIA Tesla V100-SXM2-32GB
Because of this mismatch, the driver fails to initialize correctly.
Current Status
  • Device Manager:
    • Name: NVIDIA Tesla V100-SXM2-32GB
    • Status: Error Code 10 (CM_PROB_FAILED_START)
  • nvidia-smi:
    • Output:
      NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver.
  • The NVIDIA kernel driver (nvlddmkm) is installed but remains stopped because the device fails to start.
Drivers Tested
I have tested the following NVIDIA data center drivers on Windows:
  • 551.78 – Data Center Driver
  • 582.70 – Data Center Driver
  • 462.30 – Older Data Center Driver (with this version, nvidia-smi was able to communicate with the GPU and Detected as SXM2 )
Regardless of driver version, Windows continues to identify the GPU as Tesla V100-SXM2-32GB, even though the physical card is a Tesla V100 PCIe 32GB.
Hardware IDs
From Device Manager → Details → Hardware IDs:
  • Device ID:
    PCIVEN_10DE&DEV_1DB5&SUBSYS_124910DE&REV_A1
I’d appreciate guidance on:
  • How to correctly identify the card (PCIe vs SXM2)
  • How to verify or fix the VBIOS if it is incorrect
  • Which driver and configuration should be used on Windows to get this Tesla V100-PCIE-32GB working reliably
Did anyone ever mess with the firmware on this device?
Does Device Manager also show this device under the name Tesla V100-SXM2-32GB?
I have checked the Device Manager its showing Tesla V100-SXM2-32GB.
Uploaded ss of the device manager.
So the device ID to name mapping is usually defined in an INF file in the driver package.
So I suspect that a firmware update may have changed the device ID of your PCIe card to match that of a SXM2 card. Then the driver’s INF file maps that device ID accordingly which then also shows up in Device manager under that name.
There is a tool called nvflash that is even included in some offical driver releases by nVidia, e.g. here
And there are third party downloads (usually Windows/DOS binaries) as well
I am not sure if the tool itself allows changing device IDs, and whether or not you will be able to obtain the correct VBIOS for your card. Ideally you can find another owner of the PCIe version of this card and compare device IDs and VBIOS files. Then try flashing your card to match theirs.
WARNING: there is a chance to brick you card.
Thank you very much for your help so far.
I’m sharing additional information about the GPU in case it helps identify the correct driver or determine whether this is a firmware/VBIOS compatibility issue.
GPU Information
Physical Label
  • Model: Tesla V100-PCIE-32GB
  • Part Number: 699-2G500-0212-400L
Device Information (pnputil)
Instance ID:                PCI\VEN_10DE&DEV_1DB5&SUBSYS_124910DE&REV_A1\4&27291c47&0&0008
Device Description:         NVIDIA Tesla V100-SXM2-32GB
Class Name:                 Display
Class GUID:                 {4d36e968-e325-11ce-bfc1-08002be10318}
Manufacturer Name:          NVIDIA
Status:                     Problem
Problem Code:               10 (CM_PROB_FAILED_START)
Problem Status:             0xC000009A
Driver Name:                oem6.inf
Hardware IDs:
PCI\VEN_10DE&DEV_1DB5&CC_030200
Compatible IDs:
PCI\VEN_10DE&DEV_1DB5&REV_A1
PCI\VEN_10DE&CC_030200
PCI\VEN_10DE
PCI\CC_030200&DT_0
PCI\CC_030200
PCI\CC_0302&DT_0
PCI\CC_0302
VBIOS / nvflash Information
Build GUID            : 1A634629E8A445709787DC7F202751F8
Build Number          : 25341443
IFR Subsystem ID      : 10DE-1249
Subsystem Vendor ID   : 0x10DE
Subsystem ID          : 0x1249
Version               : 88.00.80.00.04
Image Hash            : 81E49C0843498F789EE7C4E34D6D922B
Hierarchy ID          : Normal Board
Build Date            : 11/29/2018
Modification Date     : 01/10/2019
UEFI Version          : 0x4000A (x64)
UEFI Variant ID       : 0x0000000000000008 (GV1xx)
UEFI Signer(s)        : Microsoft Corporation UEFI CA 2011
XUSB-FW Version ID    : N/A
XUSB-FW Build Time    : N/A
InfoROM Version       : G503.0204.00.03
InfoROM Backup        : Not Present
License Placeholder   : Not Present
GPU Mode              : N/A
CEC OTA-signed Blob   : Not Present
