Test app stuck at `NvMMLiteBlockCreate : Block : BlockType = 261`
Jetson Nano 4g
• DeepStream Version
deepstream 6(install by .deb package)
there are my jectpack(I flashed the latest SD image at Nov 2021):
shao@shao-jsn-4g:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1$ sudo apt-cache show nvidia-jetpack
[sudo] password for shao:
Package: nvidia-jetpack
Version: 4.6-b199
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.6-b199), nvidia-opencv (= 4.6-b199), nvidia-cudnn8 (= 4.6-b199), nvidia-tensorrt (= 4.6-b199), nvidia-visionworks (= 4.6-b199), nvidia-container (= 4.6-b199), nvidia-vpi (= 4.6-b199), nvidia-l4t-jetson-multimedia-api (>> 32.6-0), nvidia-l4t-jetson-multimedia-api (<< 32.7-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6-b199_arm64.deb
SHA256: 69df11e22e2c8406fe281fe6fc27c7d40a13ed668e508a592a6785d40ea71669
SHA1: 5c678b8762acc54f85b4334f92d9bb084858907a
MD5sum: 1b96cd72f2a434e887f98912061d8cfb
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6-b197
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6-b197), nvidia-opencv (= 4.6-b197), nvidia-cudnn8 (= 4.6-b197), nvidia-tensorrt (= 4.6-b197), nvidia-visionworks (= 4.6-b197), nvidia-container (= 4.6-b197), nvidia-vpi (= 4.6-b197), nvidia-l4t-jetson-multimedia-api (>> 32.6-0), nvidia-l4t-jetson-multimedia-api (<< 32.7-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6-b197_arm64.deb
SHA256: 104cd0c1efefe5865753ec9b0b148a534ffdcc9bae525637c7532b309ed44aa0
SHA1: 8cca8b9ebb21feafbbd20c2984bd9b329a202624
MD5sum: 463d4303429f163b97207827965e8fe0
• TensorRT Version
With hdmi monitor connected and terminal run in local, always stuck here for test1 app(I didn’t compile the app by myself, it just in SDK):
shao@shao-jsn-4g:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1$ deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Now playing: /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Using winsys: x11
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:01.816215296 10161     0x140d5390 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:01.816348475 10161     0x140d5390 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:01.816381445 10161     0x140d5390 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:01:10.704430038 10161     0x140d5390 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:10.802269151 10161     0x140d5390 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
this is my xandr:
shao@shao-jsn-4g:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
   1920x1080     60.00*+  60.00    59.95
   1680x1050     59.96
   1440x900      59.89
   1280x1024     75.03    60.00
   1280x960      60.00
   1280x800      59.81
   1280x720      60.00    59.94
   1024x768      75.03    70.07    60.01
   832x624       75.05
   800x600       75.00    72.19    60.32
   720x480       59.94
   640x480       75.00    72.81    59.94
DP-0 disconnected (normal left inverted right x axis y axis)
the same behavior for test 4 app(I compiled it by myself days ago by following the steps.) which is used to upload detected object info to Kafka server, stuck same place as well though I remerber it works days ago.
• TensorRT Version
I noticed the stuck was caused by different format of video file, if I input the file of sample_720p.h264, everything is good, but input the file of sample_720p.mp4 then stuck.
  1. Is this the expected behavior?
    I checked the .mp4 file, it’s h264 encoded as well.
  2. If I want support .mp4 file as input source directly, take deepstream_python_apps test_1 souce code for example, what changes should be made to achive that:
    # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("filesrc", "file-source")
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    # Since the data format in the input file is elementary h264 stream,
    # we need a h264parser
    print("Creating H264Parser \n")
    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
    if not h264parser:
        sys.stderr.write(" Unable to create h264 parser \n")
    # Use nvdec_h264 for hardware accelerated decode on GPU
    print("Creating Decoder \n")
    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
    if not decoder:
        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
uridecoderbin is fine. please refer other samples.
