On AGX, I tried test-launch to create rtsp streaming server using local png files:
test-launch 'multifilesrc location="%07d_0.png" caps="image/png,framerate=13/1" ! pngdec ! videoconvert ! x264enc ! rtph264pay name=pay0 pt=96'
This seems to work, and I can use VLC from another client computer to view the rtsp streaming from AGX.
I then tried to convert above command to use nvidia hardware encoding/decoding:
test-launch 'multifilesrc location="%07d_0.png" caps="image/png,framerate=13/1" ! pngdec ! nvvidconv ! nvv4l2h264enc ! h264parse ! rtph264pay name=pay0 pt=96'
Now client can no longer stream. Any thoughts what could be wrong in above command?
There are some encoder properties you can set and try. Please try to enable insert-sps-pps, insert-vui, small IDR interval, baseline profile.
Tried adding those properties insert-sps-pps=true insert-vui=true idrinterval=15 profile=0
test-launch 'multifilesrc location="%07d_0.png" caps="image/png,framerate=13/1" ! pngdec ! nvvidconv ! nvv4l2h264enc insert-sps-pps=true insert-vui=true idrinterval=15 profile=0 ! h264parse ! rtph264pay name=pay0 pt=96'
Still can’t play the stream. Here is the network level capture:
OPTIONS rtsp://192.168.6.88:8554/test RTSP/1.0
CSeq: 2
User-Agent: LibVLC/3.0.9.2 (LIVE555 Streaming Media v2020.01.19)
RTSP/1.0 200 OK
CSeq: 2
Public: OPTIONS, DESCRIBE, ANNOUNCE, GET_PARAMETER, PAUSE, PLAY, RECORD, SETUP, SET_PARAMETER, TEARDOWN
Server: GStreamer RTSP server
Date: Sat, 16 Apr 2022 00:45:58 GMT
DESCRIBE rtsp://192.168.6.88:8554/test RTSP/1.0
CSeq: 3
Accept: application/sdp
RTSP/1.0 503 Service Unavailable
CSeq: 3
Found the issue. Once I rebuilt the gstreamer cache, it started working.
system
closed
#5
