Testing MCX455A bandwidth between Dell servers
I am testing MCX455A bandwidth between Dell servers using the commands:
Server: Ib_write-bw –d mlx5_0 –i 1 –a –F
and
Client: Ib_write-bw –d mlx5_0 –i 1 –a –F
The results looks fine until # bytes = 65536
Then I get the message:
mlx5: usb1 : got completion with errors
00000000 00000000 00000000 00000000
00000000 00008813 08000029 40807dd3
Problems with warm up
This test used to work to completion and I don’t think I’ve changed the configuration. I have the same problem with multiple cards (I have 13).
Thank you. That fixed it. Can you explain why?
–all / -a flag is a feature that runs traffic on all message size from 2^1 to 2^23
When not using this flag, the default message size is 64KB.
Which means that if the server side doesn’t have the ‘-a’ flag set, it will prepare it’s resources for 64KB messages… And when the client tries to send 128KB messages, it will fail.
Are you sure you used ‘-a’ flag on both client and server?
Can you please try and put the -a flag as the last flag in the command line on the server?
For the client it should be the last flag before the IP of the server.
