Hi @SivaRamaKrishnaNV, I accepted the answer before as you mentioned, any custom node integration gets logged, however we still facing issues with display.
powering off/on was the only option before, when it was irresponsive I tried with remmina vnc to have a dispaly remotely, still the same issue.
roadrunner is a black screen and launcher exit status is 33.
Hi @SivaRamaKrishnaNV friendly ping for any idea you have on this yet.
Dear @ashwin.nanda ,
I see log level is still DW_LOG_ERROR in the picture you have shared. Please use sudo ./run_cgf_demo.sh --loglevel DW_LOG_VERBOSE
to enabled verbose logs. Then, I would expect to see the prints from HelloWorldNodeImpl.cpp/SumNodeImpl.cpp
in camera_pipeline0.log to confirm if the nodes are executed.
Please double check the modified files with the files I have shared. I would expect the application to work with the steps I have provided on freshly installed machine.
Note: Please use text messages instead of pictures for logs while posting. This helps others in the community to search.
Hello @SivaRamaKrishnaNV ,
We are running the script as you have mentioned, please find the message while running the script below
20241009_140431
20241009_140431
DW_TOP_PATH=/usr/local/driveworks
RR_TOP_PATH=/usr/local/driveworks/apps/roadrunner-2.0
CGF_SYS_PATH=/usr/local/driveworks/apps/cgf_demo
RR_LOG_PATH=/usr/local/driveworks-5.14/bin/LogFolder
RR_RUN_CFG_PATH=/usr/local/driveworks-5.14/bin/RunFolder
DATA_PATH=
Current DISPLAY is :1
fs.mqueue.msg_max = 4096
|–> Tuning network stack
LD_LIBRARY_PATH: /usr/local/driveworks/apps/roadrunner-2.0:/usr/local/driveworks/src/cgf/nodes:/usr/local/driveworks/bin::/usr/local/driveworks/lib
/usr/local/driveworks-5.14/bin/LogFolder dir exists
/usr/local/driveworks-5.14/bin/RunFolder dir exists
total 12
drwxr-xr-x. 3 root root 4096 Sep 30 15:10 .
drwxr-xr-x. 5 root root 4096 Sep 30 15:10 …
drwxr-xr-x. 3 root root 4096 Sep 30 15:10 config
Running command: /usr/local/driveworks/bin/launcher --binPath=/usr/local/driveworks/bin --spec=/usr/local/driveworks/apps/cgf_demo/CGFDemo.app.json --logPath=/usr/local/driveworks-5.14/bin/LogFolder --dwdatapath=/usr/local/driveworks/data --schedule=/usr/local/driveworks/apps/cgf_demo/CGFDemo__standardSchedule.stm,/usr/local/driveworks/apps/cgf_demo/CGFDemo__slowSchedule.stm --start_timestamp=0 --loglevel=DW_LOG_VERBOSE --fullscreen=1 --winSizeW=1280 --winSizeH=800 --disableStmControlLogger=1 --gdb_debug=0 --app_parameter= --useLCM=0 --datapath=/usr/local/driveworks/data/samples/cgf/trafficlightturning-hyperion8 --mapPath=maps/sample/sanjose_loop --path=/usr/local/driveworks/apps/roadrunner-2.0 --virtual=1 > /usr/local/driveworks-5.14/bin/LogFolder/launcher.log 2>&1
Check if reset NetworkStack needed
Restore LD_LIBRARY_PATH to
launcher exit status: 33
Please find the LogFolder of the same below for your reference. Issue still persists, display cant be seen after the script is run.
LogFolder.zip (3.7 MB)
follow this to run your first minimal cgf app with just HelloworldNode and SumNode and multiple transport tested including nvsci.
nv_driveworks/README_en.md at main · ZhenshengLee/nv_driveworks (github.com)
Hi @SivaRamaKrishnaNV any updates so far? we would like to have the insight.
From camera_pipeline0_0.log
, I notice the SumNode and HelloWorldNode are executed only once.
<13>1 2024-10-09T14:05:07.552047Z - camera_pipeline0 33418 - - [1728482624924711us][DEBUG][tid:28][HelloWorldNodeImpl.cpp:78][HelloWorldNode] [Epoch 0] Sent value0 = 0
<13>1 2024-10-09T14:05:07.552105Z - camera_pipeline0 33418 - - [1728482624924775us][DEBUG][tid:28][HelloWorldNodeImpl.cpp:82][HelloWorldNode] [Epoch 0] Sent value1 = 10000
<13>1 2024-10-09T14:05:07.552122Z - camera_pipeline0 33418 - - [1728482624924792us][DEBUG][tid:28][HelloWorldNodeImpl.cpp:85][HelloWorldNode] [Epoch 0] Greetings from HelloWorldNodeImpl: Hello Demo!
<13>1 2024-10-09T14:05:07.552173Z - camera_pipeline0 33418 - - [1728482624924843us][DEBUG][tid:28][SumNodeImpl.cpp:72][SumNode] [Epoch 0] Received 0 from input VALUE_0, received 10000 from input VALUE_1. Add together: 10000!
Do you notice the same after system poweroff/on? If so, can you please re-install CGF packages and double check if CGF Demo working properly before trying modifications. Also, check adding --offscreen=1
to confirm if display is causing the app to be failed.
20241023_124047
20241023_124047
DATA_PATH=
total 12
drwxr-xr-x. 3 root root 4096 Sep 30 16:10 .
drwxr-xr-x. 5 root root 4096 Sep 30 16:10 …
drwxr-xr-x. 3 root root 4096 Sep 30 16:10 config
Running command: /usr/local/driveworks/bin/launcher --binPath=/usr/local/driveworks/bin --spec=/usr/local/driveworks/apps/cgf_demo/CGFDemo.app.json --logPath=/usr/local/driveworks-5.14/bin/LogFolder --dwdatapath=/usr/local/driveworks/data --schedule=/usr/local/driveworks/apps/cgf_demo/CGFDemo__standardSchedule.stm,/usr/local/driveworks/apps/cgf_demo/CGFDemo__slowSchedule.stm --start_timestamp=0 --loglevel=DW_LOG_VERBOSE --fullscreen=1 --offscreen=1 --winSizeW=1280 --winSizeH=800 --disableStmControlLogger=1 --gdb_debug=0 --app_parameter= --useLCM=0 --datapath=/usr/local/driveworks/data/samples/cgf/trafficlightturning-hyperion8 --mapPath=maps/sample/sanjose_loop --path=/usr/local/driveworks/apps/roadrunner-2.0 --virtual=1 > /usr/local/driveworks-5.14/bin/LogFolder/launcher.log 2>&1
launcher exit status: 0
We have added --offscreen=1 in this script.
Please find the attached LogFolder for your reference
LogFolder.tar.gz (2.3 MB)
Dear @ashwin.nanda,
Looks like sample working without any issue when display is disabled(–offscreen=1) .
Other DW samples working which need GUI output?
Yes, when we are running another sample it is showing us display. Even when running the sample CGF it is showing but when we are implementing custom node (helloworldnode and sumnode) there is no display at that time.
Dear @prit.shah ,
Make sure you are running the application in the same window where export DISPLAY:=0
is set when tested using VNC. I don’t see any issue with VNC viewer client from host.
After passing this argument we are getting another error mentioned below
> 20241029_105149
> 20241029_105149
> DATA_PATH=
> Current DISPLAY is :0
> total 12
**> Restore LD_LIBRARY_PATH to **
> launcher exit status: 217
can we have an update on this?
Is there any update on this ?
Hi @SivaRamaKrishnaNV we are awaiting a reply on this, since our custom applications for a third party DBW system and LiDAR depends on building custom nodes and graphlets for the main pipeline. If the display issue isnt sorted out even on samples, we cannot proceed ahead unless knowing which side is responsible.
I don’t see any issue with cgf_demo sample with shared steps on my side. But you seems to have issue when display is enabled. Do you have any other target to try the same steps. Or you may try reflashing once to see if fixes.
Hello there @SivaRamaKrishnaNV, I’ll cast out the situations as below:
thank you for providing the YAML, and JSON files which helped us generate node creation (verified through logs)
powering on/off, reinstalling, and even flashing are the very early and basic debugging steps performed several times.
switching to x11vnc was suggested by yourself, and do please note that the vnc and $DISPLAY environment variable use same window ( :1).
However, we DO NOT prefer to use the vnc for display losses over the network, and use a monitor connected to the target.
either way, after CGF custom node integration the display(on monitor or vnc) when the application is running is a complete black screen.
we WANT to fix this.
dear @SivaRamaKrishnaNV please also note that @prit.shah has already mentioned the logs with --off-screen=1
which resulted in the successful launcher status.
Dear @ashwin.nanda,
We have tested the CGF Demo custom node integration steps and verified the display via VNC only. We would expect it work with display as well if VNC works. It is not clear to me why it fails to run with display option where as other DW samples are able to run. Is the same behavior observed on other Devkits as well?
dear @SivaRamaKrishnaNV thank you for the reply, Ive got only one target unfortunately, however would you recommend me to switch boot-chain and try installing Driveworks 5.14 samples and deb files again on boot-chain B and try?
(also can I use boot-chain B for our own testing and development practices?)
