Dear @ashwin.nanda ,
Yes please try on other boot chain.
Hi @SivaRamaKrishnaNV thank you for the confirmation, but we tried to set the bootchain to B and reproduced the same steps again, however, we have encountered into a issue now:
pomo@tegra-ubuntu:/usr/local/driveworks$ common_if_testapp -set_next_bootchain x1 B
DU_MCC_InitResources: Failed to open NvSciIpc endpoint. err is: 0x1100
Failed to initialize IPC resource
Failed to initialize DU MCC
pomo@tegra-ubuntu:/usr/local/driveworks$ common_if_testapp -tegrareset x1
This was minicom port ACM0, as we cant access the target through monitor now
Plus when tried to clean flash again after poweron/off (through ACM1) :
2024-11-26 16:53:36 INFO : Flashing already set for dual bootchain
2024-11-26 16:53:36 INFO : Setting flash clean to initialize persistent partitions
2024-11-26 16:53:36 INFO : Initiating pre-flash check
2024-11-26 16:53:36 INFO : Checking Serial Port Connection
2024-11-26 16:53:36 INFO : Serial Port found /dev/ttyACM1
2024-11-26 16:53:36 INFO : Running basic open/close tests on Serial Port Connection
2024-11-26 16:53:36 INFO : Serial Port is open
2024-11-26 16:53:36 INFO : Flushing input and output buffer, discard all content
2024-11-26 16:53:36 INFO : Serial Port is closed
2024-11-26 16:53:36 INFO : Checking available targets
2024-11-26 16:53:36 INFO : Checking Orin board connection
2024-11-26 16:53:36 INFO : Orin board with Device ID -- 0955:7045 found.
2024-11-26 16:53:36 INFO : Orin board device path is /dev/bus/usb/003/040
2024-11-26 16:53:36 INFO : Pre-flash check complete
2024-11-26 16:53:36 INFO : Flashing DRIVE OS Docker
2024-11-26 16:53:56 INFO : driveinstaller v2.0
2024-11-26 16:53:56 INFO : SDK/PDK Installer and Flasher
2024-11-26 16:53:56 INFO : Run `./driveinstaller --help` for usage information.
2024-11-26 16:53:56 INFO : Initializing board and OS configuration to Autonomous vehicle p3710 Linux Tegra A
2024-11-26 16:53:56 INFO : Manifest version 2.0
2024-11-26 16:53:56 INFO : BOARD SKU : 940-63710-0010-300
2024-11-26 16:53:56 INFO : Found matching board id p3710-10-s05 in 940-63710-0010-300 sku
2024-11-26 16:53:56 INFO : Applying additional Bind opts []
2024-11-26 16:53:56 INFO : Binding of partitions failed ! Check log for more details.
2024-11-26 16:53:56 INFO : Failed to bind partitions!
2024-11-26 16:53:56 INFO : driveinstaller cannot continue! Check the log file for details: /drive/driveinstaller/driveinstaller.log
2024-11-26 16:53:56 ERROR : Flashing failed, please contact provider with logs /drive_flashing/log_3chr046pu8jm1d7kyxw9ebvqa5fz2sli.txt and /drive/driveinstaller/driveinstaller.log.
attached the flash logs as well:
driveinstaller.log (175.5 KB)
dear @SivaRamaKrishnaNV please note that I tried resetting the SoC through ACM1 as well, however no effects.
dear @SivaRamaKrishnaNV Im creating a new thread regarding this, this has lead to divergent problems with the SoC.
It is not clear why flashing is tried again. Do you any issue with booting into another bootchain? Please file a new topic
@SivaRamaKrishnaNV CGF custom node integration fails with display, we have decided to run the applications in offscreen mode for now.
Dear @SivaRamaKrishnaNV ,
We are making the new thread for the Custom CGF Issue
CGF custom node integration queries will be handled by @prit.shah from now on.
