When using deepstream with T4 seeing performance degradation over time + when performing basic cuda test it fails , see below:
test failed after 280*10 iterations
step 280
terminate called after throwing an instance of ‘cv::Exception’
what(): OpenCV(3.4.5) /home/nvidia/opencv/modules/core/src/cuda/gpu_mat.cu:224: error: (-217:Gpu API call) unknown error in function ‘upload’
#include
#include <opencv2/core/cvstd.hpp>
#include <opencv2/core/mat.hpp>
#include <opencv2/cudaimgproc.hpp>
#include <opencv2/cudabgsegm.hpp>
#include <opencv2/cudalegacy.hpp>
#include <opencv2/cudaarithm.hpp>
int main()
std::cout << "Number of gpu devices: " << cv::cuda::getCudaEnabledDeviceCount() << std::endl;
cv::Mat cpuMat_1, cpuMat_2;
cv::cuda::GpuMat gpuMat_1, gpuMat_2, gpuMat_3;
int i=0;
while(i<1000){
cpuMat_1 = cv::Mat::ones(14000, 14000, CV_8SC1);
cpuMat_2 = cv::Mat::ones(14000, 14000, CV_8SC1);
gpuMat_1.upload(cpuMat_1);
gpuMat_2.upload(cpuMat_2);
cv::cuda::add(gpuMat_1, gpuMat_2, gpuMat_3);
if((i%10) == 0){
std::cout << “step” << " " << i << “\n”;
i++;
std::cout << “done.”;
return 0;
Same tests work on V100.
Tested with two different T4 cards , is it a known issue? / Could it be a driver - cuda - ocv - deepstream versions issue?
