We’re trying to implement a simple gripper that works not by grasp friction but by tethering the object to the gripper when the gripper is close enough. How would you implement this in Isaac Gym?
What we’re doing right now is overriding the root state of the object and setting it to be the position and orientation of the gripper.
However, this way, the weight of the object is not affecting the arm. Is there a better way of doing that?
In PyBullet, we could dynamically create a constraint that does this, i.e. that says that the object will now move at a fixed distance with the gripper.
EDIT: we’re not trying to do friction-based grasping because we don’t care about the actual grasping part. We just want the arm to “hold” the object when the gripper is close enough.
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
from omni.isaac.dynamic_control import _dynamic_control
from omni.isaac.manipulators.grippers.gripper import Gripper
from omni.isaac.surface_gripper._surface_gripper import Surface_Gripper
from omni.isaac.surface_gripper._surface_gripper import Surface_Gripper_Properties
from omni.isaac.core.utils.types import ArticulationAction
import numpy as np
import carb
import omni.kit.app
class SurfaceGripper(Gripper):
"""Provides high level functions to set/ get properties and actions of a surface gripper
(a suction cup for example).
Args:
end_effector_prim_path (str): prim path of the Prim that corresponds to the gripper root/ end effector.
translate (float, optional): _description_. Defaults to 0.
direction (str, optional): _description_. Defaults to "x".
grip_threshold (float, optional): _description_. Defaults to 0.01.
force_limit (float, optional): _description_. Defaults to 1.0e6.
torque_limit (float, optional): _description_. Defaults to 1.0e4.
bend_angle (float, optional): _description_. Defaults to np.pi/24.
kp (float, optional): _description_. Defaults to 1.0e2.
kd (float, optional): _description_. Defaults to 1.0e2.
disable_gravity (bool, optional): _description_. Defaults to True.
def __init__(
self,
end_effector_prim_path: str,
translate: float = 0,
direction: str = "x",
grip_threshold: float = 0.01,
force_limit: float = 1.0e6,
torque_limit: float = 1.0e4,
bend_angle: float = np.pi / 24,
kp: float = 1.0e2,
kd: float = 1.0e2,
disable_gravity: bool = True,
) -> None:
Gripper.__init__(self, end_effector_prim_path=end_effector_prim_path)
self._dc_interface = _dynamic_control.acquire_dynamic_control_interface()
self._translate = translate
self._direction = direction
self._grip_threshold = grip_threshold
self._force_limit = force_limit
self._torque_limit = torque_limit
self._bend_angle = bend_angle
self._kp = kp
self._kd = kd
self._disable_gravity = disable_gravity
self._virtual_gripper = None
self._articulation_num_dofs = None
return
def initialize(
self, physics_sim_view: omni.physics.tensors.SimulationView = None, articulation_num_dofs: int = None
) -> None:
"""Create a physics simulation view if not passed and creates a rigid prim view using physX tensor api.
This needs to be called after each hard reset (i.e stop + play on the timeline) before interacting with any
of the functions of this class.
Args:
physics_sim_view (omni.physics.tensors.SimulationView, optional): current physics simulation view. Defaults to None
articulation_num_dofs (int, optional): num of dofs of the Articulation. Defaults to None.
Gripper.initialize(self, physics_sim_view=physics_sim_view)
self._articulation_num_dofs = articulation_num_dofs
virtual_gripper_props = Surface_Gripper_Properties()
virtual_gripper_props.parentPath = self._end_effector_prim_path
virtual_gripper_props.d6JointPath = virtual_gripper_props.parentPath + "/d6FixedJoint"
virtual_gripper_props.gripThreshold = self._grip_threshold
virtual_gripper_props.forceLimit = self._force_limit
virtual_gripper_props.torqueLimit = self._torque_limit
virtual_gripper_props.bendAngle = self._bend_angle
virtual_gripper_props.stiffness = self._kp
virtual_gripper_props.damping = self._kd
virtual_gripper_props.disableGravity = self._disable_gravity
tr = _dynamic_control.Transform()
if self._direction == "x":
tr.p.x = self._translate
elif self._direction == "y":
tr.p.y = self._translate
elif self._direction == "z":
tr.p.z = self._translate
else:
carb.log_error("Direction specified for the surface gripper doesn't exist")
virtual_gripper_props.offset = tr
virtual_gripper = Surface_Gripper(self._dc_interface)
virtual_gripper.initialize(virtual_gripper_props)
self._virtual_gripper = virtual_gripper
if self._default_state is None:
self._default_state = not self.is_closed()
return
def close(self) -> None:
"""Applies actions to the articulation that closes the gripper (ex: to hold an object).
if not self.is_closed():
self._virtual_gripper.close()
carb.log_warn("gripper didn't close successfully")
return
def open(self) -> None:
"""Applies actions to the articulation that opens the gripper (ex: to release an object held).
result = self._virtual_gripper.open()
if not result:
return
def update(self) -> None:
self._virtual_gripper.update()
return
def is_closed(self) -> bool:
return self._virtual_gripper.is_closed()
def set_translate(self, value: float) -> None:
self._translate = value
return
def set_direction(self, value: float) -> None:
self._direction = value
return
def set_force_limit(self, value: float) -> None:
self._force_limit = value
return
def set_torque_limit(self, value: float) -> None:
self._torque_limit = value
return
def set_default_state(self, opened: bool):
"""Sets the default state of the gripper
Args:
opened (bool): True if the surface gripper should start in an opened state. False otherwise.
self._default_state = opened
return
def get_default_state(self) -> dict:
"""Gets the default state of the gripper
Returns:
dict: key is "opened" and value would be true if the surface gripper should start in an opened state. False otherwise.
return {"opened": self._default_state}
def post_reset(self):
Gripper.post_reset(self)
if self._default_state: # means opened is true
self.open()
else:
self.close()
return
def forward(self, action: str) -> ArticulationAction:
"""calculates the ArticulationAction for all of the articulation joints that corresponds to "open"
or "close" actions.
Args:
action (str): "open" or "close" as an abstract action.
Raises:
Exception: _description_
Returns:
ArticulationAction: articulation action to be passed to the articulation itself
(includes all joints of the articulation).
if self._articulation_num_dofs is None:
raise Exception(
"Num of dofs of the articulation needs to be passed to initialize in order to use this method"
if action == "open":
self.open()
elif action == "close":
self.close()
else:
raise Exception("action {} is not defined for SurfaceGripper".format(action))
return ArticulationAction(joint_positions=[None] * self._articulation_num_dofs)
this code is from here:
exts/omni.isaac.manipulators/omni/isaac/manipulators/grippers/surface_gripper.py
you can modify grip thresold. This essentially create a fixed joint between object and the gripper. I belive you can also do it manually creating a fixed joint
It seems this paper did something similar, but they did not release code yet.
