In my CUDA application I noticed that tex1Dfetch is not returning the correct value, past a certain index in the buffer. An initial observation in the application was that a value at index 0 could be read correctly, but at 12705625, the value read was 0. I made a small test program to investigate this, given below. The results are a little bit baffling to me. I’m trying to probe at what index the values no longer are read correctly. But as the value arraySize is changed, so does the “firstBadIndex”. Even with arraySize =2, the second value is read incorrectly! As arraySize is made bigger, the firstBadIndex gets bigger. This happens when binding float, float2, or float4. If the data are read from the device buffer instead (switch around the commented lines in FetchTextureData), then everything is fine. This is using CUDA 6.5, on a Tesla c2075.
Thanks for any insights or advice you might have.
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
#define FLOATTYPE float4
texture<FLOATTYPE,cudaTextureType1D,cudaReadModeElementType> texture1D;
const unsigned int arraySize = 1000;
FLOATTYPE* host;
FLOATTYPE* device;
FLOATTYPE* dTemp;
FLOATTYPE hTemp[1];
__global__ void FetchTextureData(FLOATTYPE* data,FLOATTYPE* arr,int idx)
data[0] = tex1Dfetch(texture1D, idx);
//data[0] = arr[idx];
bool GetTextureValues(int idx){
FetchTextureData<<<1,1>>>(dTemp,device,idx);
// copy to the host
cudaError_t err = cudaMemcpy(hTemp,dTemp,sizeof(FLOATTYPE),cudaMemcpyDeviceToHost);
if (err != cudaSuccess) {
throw "cudaMemcpy failed!";
if (cudaDeviceSynchronize() != cudaSuccess) {
throw "cudaDeviceSynchronize failed!";
return hTemp[0].x == 1.0f;
int main()
try{
host = new FLOATTYPE[arraySize];
cudaError_t err = cudaMalloc((void**)&device,sizeof(FLOATTYPE) * arraySize);
cudaError_t err1 = cudaMalloc((void**)&dTemp,sizeof(FLOATTYPE));
if (err != cudaSuccess || err1 != cudaSuccess) {
throw "cudaMalloc failed!";
// make some host data
for(unsigned int i=0; i<arraySize; i++){
FLOATTYPE data = {1.0f, 0.0f, 0.0f, 0.0f};
host[i] = data;
// and copy it to the device
err = cudaMemcpy(device,host,sizeof(FLOATTYPE) * arraySize,cudaMemcpyHostToDevice);
if (err != cudaSuccess){
// set up the textures
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<FLOATTYPE>();
texture1D.addressMode[0] = cudaAddressModeClamp;
texture1D.filterMode = cudaFilterModePoint;
texture1D.normalized = false;
cudaBindTexture(NULL, texture1D, device, channelDesc, arraySize);
// do a texture fetch and find where the fetches stop working
int lastGoodValue = -1, firstBadValue = -1;
float4 badValue = {-1.0f,0.0f,0.0f,0.0f};
if(i % 100000 == 0) printf("%d\n",i);
bool isGood = GetTextureValues(i);
if(firstBadValue == -1 && !isGood)
firstBadValue = i;
if(isGood)
lastGoodValue = i;
else
badValue = hTemp[0];
printf("lastGoodValue %d, firstBadValue %d\n",lastGoodValue,firstBadValue);
printf("Bad value is (%.2f)\n",badValue.x);
}catch(const char* err){
printf("\nCaught an error : %s\n",err);
return 0;
