Hello, I’m testing this on the currently available latest release of KDE Plasma on Fedora 44 which is version 6.7.5, and nvidia drivers 615.71.09, but this issue has always been happening for me, I’ve also made a bug report on the GTK gitlab and the KDE Plasma gitlab:
And by troubleshooting with the help of AI I’ve figured out that this is most probably a NVIDIA Driver bug.
As the title says, the text transitions of Libadwaita apps specifically on KDE Plasma leave a line of glitching pixels behind them, and the easiest way to reproduce this issue is to install the Bazaar store from flathub (https://flathub.org/en/apps/io.github.kolunmi.Bazaar), open a random app that has got an “i” in it’s name (but this issue also happens with other letters), then scroll down enough until the name of the app appears on the top of Bazaar, then scroll up again to make the title of the app disappear, and then this issue will happen:
flatpak run --env=GSK_RENDERER=cairo io.github.kolunmi.Bazaar which will use software rendering and this issue will not happen.
According to AI this is a frame buffer issue with the NVIDIA driver:
“NVIDIA Driver Front-Buffer Gaps: The proprietary NVIDIA driver (especially versions like your 610.57.04) sometimes fails to sync textures perfectly with Wayland subsurfaces during quick transitions. The “line of pixels” you see is likely a residual frame buffer slice that didn’t receive a clear command before the next frame was drawn.”
System Configuration:
- OS: Fedora 44 KDE Plasma
- Desktop Environment: KDE Plasma 6.7.5 (Wayland session)
- GPU: RTX 4070
- Driver Version: 615.71.09
- Monitor/Scaling: 1920 x 1080, 144hz, 100% scaling
nvidia-bug-report.log.gz (592.8 KB)
