I thought I had texture addressing sorted, but now i’m not so sure…
I understood that if I set a texture as unnormalised cudaFilterModePoint, then what I get back in the kernel should be the same as what I put in at the CPU: ie no interpolation happening. However I consistently get slightly different values back (simplified code below), but not quite the same. What am I missing here?
texture<unsigned char, 2, cudaReadModeElementType> bitmapTexture;
// send an image up as a texture
// RGB only, as send as unsigned char
void doKernel( unsigned char *bitmap,
unsigned long bitmap_step,
unsigned bitmap_width,
unsigned bitmap_height,
unsigned channelCount // 3 for rgb
cudaArray *cuArray1;
cudaChannelFormatDesc channelDescBitmap = cudaCreateChannelDesc<unsigned char>();
cudaMallocArray(&cuArray1,&channelDescBitmap,bitmap_width * channelCount,bitmap_height);
cudaMemcpy2DToArray(
cuArray1, 0,0,bitmap,bitmap_step * sizeof(unsigned char),
bitmap_width * sizeof(unsigned char),
bitmap_height * sizeof(unsigned char),
cudaMemcpyHostToDevice);
bitmapTexture.addressMode[0] = cudaAddressModeWrap;
bitmapTexture.addressMode[1] = cudaAddressModeWrap;
bitmapTexture.filterMode = cudaFilterModePoint;
cudaBindTextureToArray(bitmapTexture, cuArray1, channelDescBitmap);
dim3 dimBlock(1); // just for demo
dim3 dimGrid(1);
odd_kernel<<<dimGrid, dimBlock>>>();
global void odd_kernel()
int incomingXbytes = 5;
int incomingYbytes = 2;
// these are very close, but not quite, say 65 vs 64
unsigned char componentValue_R = tex2D(bitmapTexture, incomingXbytes, incomingYbytes);
unsigned char componentValue_G = tex2D(bitmapTexture, incomingXbytes+1, incomingYbytes);
unsigned char componentValue_B = tex2D(bitmapTexture, incomingXbytes+2, incomingYbytes);
