In the Resources View, how should the GPU memory consumed by Texture Buffer Objects (TBOs) be displayed? Shouldn’t the GPU mem size for the thin Texture wrapper be 0?
What I’m seeing in Nsight Graphics is that, for a single TBO, there is an entry for the “Buffer” object and an entry for the thin “Texture” wrapper (that’s good). However, the GPU memory space consumed by the buffer object is reported on both the Buffer object and on the Texture wrapper. That is, the space is double-counted.
Minor feature request: It’d be helpful if the size reported for the Texture wrapper was 0 (or whatever its actual GPU memory footprint is).
Why I mention this is that I’d like to use a spreadsheet to compute a sum of the Memory size across all (or a subset) of the resources in the CSV dump to estimate total app GPU mem consumption (excluding NV driver internal-use buffers, of course). If I do this, the mem for TBOs will be double-counted, unless I special-case TBOs and pre-filter out their Texture wrappers.
This is on Nsight Graphics v2020.1.1.0.
