Hi, I’m finding that the clamp addressing mode (out of bound access) does not work for my 2D texture. Basically I get garbage, instead of the value that is at the edge of the texture. Has anybody encountered this?
Here is how I created the texture:
texture<unsigned short,2,cudaReadModeNormalizedFloat> texRef_s;
size_t offset;
cudaChannelFormatDesc desc = cudaCreateChannelDesc<unsigned short>();
// set texture parameters
texRef_s.addressMode[0] = cudaAddressModeClamp;
texRef_s.addressMode[1] = cudaAddressModeClamp;
texRef_s.filterMode = cudaFilterModeLinear;
texRef_s.normalized = false;
bool status = true;
cudaError_t CUDAstatus;
if ((CUDAstatus = cudaBindTexture2D (&offset, texRef_s, d_proj, desc, columns, rows, pitch)) != cudaSuccess) {
fprintf(stderr,"Cuda Error : %s %s %d\n", cudaGetErrorString(CUDAstatus), __FILE__, __LINE__);
status = false;
// d_proj is an array allocated earlier with cudaMallocPitch(&d_proj, &pitch_s, sizeof(unsigned short)*columns, rows);
The texture gets bound correctly (otherwise, the code above would return an error).
Also, the values fetched from the interior of the texture (valid range access) are correct.
Any clues as to why I get garbage values for out-of-bounds texture fetches??
