Hi
The following code is from programming guide 3.0 page number 32.
I am unable to understand the following wrt to the code:
1-What exactly the kernel transformKernel doing here? My vague understanding says that the kernel is reading some data using texture. But why we tranformed the coordinates (float tu = u * cosf(theta) – v * sinf(theta) + 0.5f; float tv = v * cosf(theta) + u * sinf(theta) + 0.5f;).
Specifically the job done by the function tex2D(tex, tu, tv); is not clear to me. Are we reading data at location specified at (tu, tv)?
2-cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
In the above statement why the particular values 32, 0, 0, 0, have been chosen?
I am sure once I understand these two points I will not be asking such newbie questions.
Please help me understand this.
// 2D float texture
texture<float, 2, cudaReadModeElementType> texRef;
// Simple transformation kernel
__global__ void transformKernel(float* output,
int width, int height, float theta)
// Calculate normalized texture coordinates
unsigned int x = blockIdx.x * blockDim.x + threadIdx.x;
unsigned int y = blockIdx.y * blockDim.y + threadIdx.y;
float u = x / (float)width;
float v = y / (float)height;
// Transform coordinates
u -= 0.5f;
v -= 0.5f;
// Read from texture and write to global memory
output[y * width + x] = tex2D(tex, tu, tv);
// Host code
int main()
// Allocate CUDA array in device memory
cudaArray* cuArray;
cudaMallocArray(&cuArray, &channelDesc, width, height);
// Copy to device memory some data located at address h_data
// in host memory
cudaMemcpyToArray(cuArray, 0, 0, h_data, size,
cudaMemcpyHostToDevice);
// Set texture parameters
texRef.addressMode[0] = cudaAddressModeWrap;
texRef.addressMode[1] = cudaAddressModeWrap;
texRef.filterMode = cudaFilterModeLinear;
texRef.normalized = true;
// Bind the array to the texture
cudaBindTextureToArray(texRef, cuArray, channelDesc);
// Allocate result of transformation in device memory
float* output;
cudaMalloc((void**)&output, width * height * sizeof(float));
// Invoke kernel
dim3 dimBlock(16, 16);
dim3 dimGrid((width + dimBlock.x – 1) / dimBlock.x,
(height + dimBlock.y – 1) / dimBlock.y);
transformKernel<<<dimGrid, dimBlock>>>(output, width, height,
angle);
// Free device memory
cudaFreeArray(cuArray);
cudaFree(output);
