texture interpolation Tesla precision issue?
Hi Everybody,
I have an interesting issue with 3D texture interpolation that maybe someone else has seen (or can spot a mistake I’m making).
I am trying to interpolate a 3D volume with textures and without. I have recreated the trilinear interpolation method described in the CUDA C programming guide for the non-texture version so that in theory the results should be the same. Ill post the code here reducing to just the involved sections.
Im testing on both a Tesla c2050(CUDA TK3.2) and a GeForce G 210M (CUDA TK4) (both with identical results)
Im currently copying data, and calling the kernel with a MATLAB mex file but I have this texture issue without involving matlab so Im pretty sure its not involved.
I have a very simple test volume which is a 10x10x10 array of zeros with a cube of ones [4:6,4:6,4:6] in the centre. I copy the volume into a cudaArray texture and also a global memory array and i interpolate one with texture calls and the other with an interpolation function.
If i just sample the data in the texture right in the middle of each voxel (i.e. no interpolation) then I get the correct volume back.
The values that return from the interpolation function are what i would expect. but the values from the textures are oddly different
for example if i interpolate in 0.1 steps between a [0] voxel and a [1] voxel,
the interpolation function would give me [0,0.1 , 0.2 , 0.3 , 0.4 , 0.5, 0.6 , 0.7 , 0.8 , 0.9 , 1]; — correct
the texture interpolation would give me [0,0.1016, 0.1992, 0.3008, 0.3984, 0.5, 0.6016, 0.6992, 0.8008, 0.8984, 1]; — oddly incorrect
If anyone can offer a suggestion of where to look I would be very grateful and would owe them a drink.
heres the code, sorry if its not correct to dump code. (long time lurker, first time poster)
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include <cutil_inline.h>
#include <cutil.h>
#include “mex.h”
texture<float, 3, cudaReadModeElementType> VolComtex;
// GPU INTERPOLATE MIMIC BEGIN
//interpolation function to mimic texture memory interpolation (only used when textures are not used)
device float GPUInterpolate(const float * Vol,
float lx,
float ly,
float lz,
int sx,
int sy,
int sz)
float value = 0;
float alpha = 0;
float beta = 0;
float gamma = 0;
float floorx, floory, floorz;
//precalculate floor values
floorx	=	floor(lx);
floory	=	floor(ly);
floorz	=	floor(lz);
//get weights for each direction based on distance
alpha	=	lx-floorx;
beta	=	ly-floory;
gamma	=	lz-floorz;
//catch centre voxel requests and let value = voxel value and return it (faster)
if (alpha==0 && beta==0 && gamma==0)
	value	=	Vol[int(lx+ly*sx+lz*sx*sy)];
	return (value);
float xyz		=	0;
float xxyz		=	0;
float xyyz		=	0;
float xyzz		=	0;
float xxyyz		=	0;
float xxyzz		=	0;
float xyyzz		=	0;
float xxyyzz	        =       0;
int px			=	1;
int py			=	1;
int pz			=	1;
//catch edge requests and let them equal the edge (as they will have weight 0 anyway)
if (lz==(sz-1)) pz=0;
if (ly==(sy-1)) py=0;
if (lx==(sx-1)) px=0;
//get value of the 8 bounding voxels
xyz	=	Vol[int((floorx) + (floory*sx) + (floorz*sx*sy))];		//value at corner int voxel(x,y,z)
xxyz	=	Vol[int((floorx+px) + (floory*sx) + (floorz*sx*sy))];		//value at corner int voxel(x+1,y,z)
xyyz	=	Vol[int(floorx + ((floory+py)*sx) + (floorz*sx*sy))];		//value at corner int voxel(x,y+1,z)
xyzz	=	Vol[int(floorx + ((floory)*sx) + ((floorz+pz)*sx*sy))];		//value at corner int voxel(x,y,z+1)
xxyyz	=	Vol[int((floorx+px) + ((floory+py)*sx) + ((floorz)*sx*sy))];	//value at corner int voxel(x+1,y+1,z)
xxyzz	=	Vol[int((floorx+px) + ((floory)*sx) + ((floorz+pz)*sx*sy))];	//value at corner int voxel(x+1,y,z+1)
xyyzz	=	Vol[int(floorx + ((floory+py)*sx) + ((floorz+pz)*sx*sy))];	//value at corner int voxel(x,y+1,z+1)
xxyyzz	=	Vol[int((floorx+px) + ((floory+py)*sx) + ((floorz+pz)*sx*sy))];	//value at corner int voxel(x+1,y+1,z+1)
//get interpolated value of loaction based on weighted values of surrounding voxels
value	=	((1-alpha)*(1-beta)*(1-gamma)*(xyz)) + (alpha*(1-beta)*(1-gamma)*(xxyz))
			+ (beta*(1-alpha)*(1-gamma)*(xyyz)) + (alpha*beta*(1-gamma)*(xxyyz))
			+ (gamma*(1-alpha)*(1-beta)*(xyzz)) + (alpha*gamma*(1-beta)*(xxyzz))
			+ (beta*gamma*(1-alpha)*(xyyzz)) + (alpha*beta*gamma*(xxyyzz));
return (value);
//-----END of GPU INTERPOLATE MIMIC ---------------------------------------------------------------------------
// GPU TEST KERNEL BEGIN
global void testkernel( float * GammaOUT,
float * DoseDiffOUT,
const float * VolRef,
float szXr,
float szYr,
float szZr,
float szXc,
float szYc,
float szZc)
// This is the threadIdx index counter
    int idx		=	(threadIdx.x + (threadIdx.y * (blockDim.x)) + (threadIdx.z * (blockDim.x*blockDim.y))) + ( (blockIdx.x * blockDim.x * blockDim.y * blockDim.z)) + ( (blockIdx.y * gridDim.x * blockDim.x * blockDim.y * blockDim.z));
//initalise GammOUT / DoseDiffOUT and set Distance / Dose to 99999 to avoid resusing values
GammaOUT[idx]            = 0;//99999;
DoseDiffOUT[idx]		 = 0;//99999;
float idxComDose		 = 0;//99999;
float idxRefDose		 = 0;//99999;
int irX = 0;
int irY = 0;
int irZ = 0;
int icX	= 0;
int icY = 0;
int icZ = 0;
// Determine x,y,z from idx of the Reference vol
irX		=	floor(fmodf(idx,(szXr)));
irY		=	floor(fmodf((int)(idx) / (int)(szXr),szYr));
irZ		=	floor(fmodf((int)(idx) / (int)(szXr*szYr),szZr));
// Determine x,y,z from idx of the Compare vol
icX		=	fmodf(idx,(szXc));
icY		=	fmodf((int)(idx) / (int)(szXc),szYc);
icZ		=	fmodf((int)(idx) / (int)(szXc*szYc),szZc);
float offset=	0.1f;
    //interpolate along x axis in steps of 0.1 between a 0 voxel and a 1 voxel
idxComDose		=	tex3D(VolComtex,2+0.5f+(offset*icX), icY+0.5f, icZ+0.5f);
idxRefDose		=	GPUInterpolate(VolRef,2+(offset*icX),irY,irZ,szXr,szYr,szZr);
//output the results
GammaOUT[idx]       =	idxComDose;
DoseDiffOUT[idx]	=	idxRefDose;
//these are just checks that i know the kernel actually ran
GammaOUT[0]=1;
DoseDiffOUT[1]=2;
//KERNEL END
MAIN MEX FUNCTION /
void mexFunction(int nlhs,mxArray *plhs,int nrhs,const mxArray *prhs)
// pointers for the variables
double * GammaOUT;			// OUT  0
double * DoseDiffOUT;		        // OUT  1
double * VolRef;			// IN   0
double * VolCom; 			// IN   1
float szXr;				// IN	2
float szYr; 				// IN	3
float szZr; 				// IN	4
float szXc; 				// IN	5
float szYc; 				// IN	6
float szZc;				// IN	7
// Vector data
VolRef           = mxGetPr(prhs[0]);  //0
VolCom           = mxGetPr(prhs[1]);  //1
// Value parameters
szXr                  = *(double*)(mxGetPr(prhs[2])); //2
szYr                  = *(double*)(mxGetPr(prhs[3])); //3
szZr                  = *(double*)(mxGetPr(prhs[4])); //4
szXc                  = *(double*)(mxGetPr(prhs[5])); //5
szYc                  = *(double*)(mxGetPr(prhs[6])); //6
szZc                  = *(double*)(mxGetPr(prhs[7])); //7
// allocate memory for output
mwSize dims[]	=	{szXr*szYr*szZr,1,1};
mwSize ndim = 3;
plhs[0] = mxCreateNumericArray( ndim, dims, mxDOUBLE_CLASS, mxREAL );
plhs[1] = mxCreateNumericArray( ndim, dims, mxDOUBLE_CLASS, mxREAL );
// get output/input pointers
GammaOUT			=	mxGetPr(plhs[0]);
DoseDiffOUT			=	mxGetPr(plhs[1]);
float *GOUT			=	(float *) mxMalloc((szXr*szYr*szZr)*sizeof(float));
float *DOUT			=	(float *) mxMalloc((szXr*szYr*szZr)*sizeof(float));
float *RefData		        =	(float *) mxMalloc((szXr*szYr*szZr)*sizeof(float));
float *CompData		        =	(float *) mxMalloc((szXc*szYc*szZc)*sizeof(float));
for (int i = 0; i < (int)(szXr*szYr*szZr); i++)
		RefData[i]	=	(float)(VolRef[i]);
for (int i = 0; i < (szXc*szYc*szZc); i++)
		CompData[i]     =	(float)(VolCom[i]);
cudaSetDevice(0);
//create a cudaExtent, describing a Volume for a cudaArray which will be a texture;
cudaExtent ComVolumeSize	        =	make_cudaExtent(szXc, szYc, szZc);
//create a channel descriptor that describes variables pulled from texture mem
cudaChannelFormatDesc channelDesc	=	cudaCreateChannelDesc<float>();
//allocate mem for the 3D cudaArray
cutilSafeCall(cudaMalloc3DArray(&Vol3D2_cuArray, &channelDesc, ComVolumeSize));
size_t ComSize	=	ComVolumeSize.width* ComVolumeSize.height *ComVolumeSize.depth;
//set copy parameters and copy Volumes to Array
cudaMemcpy3DParms ComCopyParams = {0};
ComCopyParams.srcPtr	=	make_cudaPitchedPtr((void*)CompData,ComVolumeSize.width*sizeof(float), ComVolumeSize.width, ComVolumeSize.height);
ComCopyParams.dstArray	=	Vol3D2_cuArray;
ComCopyParams.extent	=	ComVolumeSize;
ComCopyParams.kind	=	cudaMemcpyHostToDevice;
cutilSafeCall( cudaMemcpy3D(&ComCopyParams) );
//specify texture reference parameters
VolComtex.normalized		=	false;
VolComtex.filterMode		=	cudaFilterModeLinear;
VolComtex.addressMode[0]	=	cudaAddressModeClamp;
VolComtex.addressMode[1]	=	cudaAddressModeClamp;
VolComtex.addressMode[2]	=	cudaAddressModeClamp;
//Bind the array to the texture references
cutilSafeCall(cudaBindTextureToArray(VolComtex, Vol3D2_cuArray, channelDesc));
//declare variables / pointers for GPU
size_t GSize	=	(szXr)*(szYr)*(szZr)*sizeof(float);
float *GGVol, *GGDose, *GVolume3D1;
// allocate memory on GPU
cutilSafeCall(cudaMalloc((void**)&GGVol, GSize));
cutilSafeCall(cudaMalloc((void**)&GGDose, GSize));
cutilSafeCall(cudaMalloc((void**)&GVolume3D1, GSize));
//copy variables from host memory to device memory
cutilSafeCall(cudaMemcpy(GGVol,  GammaOUT, GSize, cudaMemcpyHostToDevice));
cutilSafeCall(cudaMemcpy(GGDose, DoseDiffOUT, GSize, cudaMemcpyHostToDevice));
cutilSafeCall(cudaMemcpy(GVolume3D1, RefData,  GSize, cudaMemcpyHostToDevice));
//define grid and block size and then invoke GPU kernel (manually or based on dimensions of volume)
int BlockX	=	10;
int BlockY	=	10;
int GridX	=	10;//128;
int GridY	=	1;//(szXc*szYc*szZc)/(BlockX*BlockY*GridX);
dim3 dimBlock(BlockX,BlockY);
dim3 dimGrid(GridX,GridY);
//sync threads
cudaThreadSynchronize();
//call GPU Kernel
testkernel<<<dimGrid,dimBlock>>>(GGVol,GGDose,GVolume3D1,szXr,szYr,szZr,szXc,szYc,szZc);
//sync threads (wait until all kernel threads are complete)
//allocate memory on host and copy variables from DEVICE to HOST
cudaMemcpy(GOUT, GGVol, GSize, cudaMemcpyDeviceToHost);
cudaMemcpy(DOUT, GGDose, GSize, cudaMemcpyDeviceToHost);
for (int i = 0; i< (szXr*szYr*szZr); i++)
		GammaOUT[i]			= (double)(GOUT[i]);
		DoseDiffOUT[i]		        = (double)(DOUT[i]);
//free Device Memory
cutilSafeCall(cudaFree(GGVol));
cutilSafeCall(cudaFree(GGDose));
cutilSafeCall(cudaFree(GVolume3D1));
//sync threads
//free Host Memory
mxFree(GOUT);
mxFree(DOUT);
mxFree(RefData);
mxFree(CompData);
The fractional position between two voxels is rounded to one of only 256 values, which saves transistors in the texture units. If you have higher precision requirements (and cannot ensure you’ll only interpolate the texture at exactly those positions), you’ll have to do it manually instead of using the texture hardware.
Hi Tera,
Thanks for your quick and clear answer. You couldn’t point me in the direction of the literature on this? I’ve been having trouble finding some that deals with textures in depth.
Many Thanks,
Marx_01
See appendix E of the programming guide.
