Texture Memory with double precision elements. Any possibility?
Hello.
I wonder if I can use the texture memory with double precision elements.
Is there any trick or any indirect way?
Thank you.
Yes. You can keep 32-bit int values in texture memory and then combine them using function
double result=__hiloint2double(hi,lo);
You won’t be able to automatically interpolate though…
