I am hoping that someone has someone has some ideas on how to improve texture upload speeds on Tegra 3 h/w. In comparison to other chipsets around the same time (2012-2013) the Tegra 3 doesn’t seem to perform very well.
Below are the results for tests on an Asus transformer (with a Tegra 3 gfx chip) and a Samsung Tab 2 (PowerVR SGX540) - which appears to run better. The results show performance alone and under load (in game)
Asus TF300T 1GB RAM [1280 x 760] Quad Core
GPU: Nvidia Tegra 3 T30L: CPU: ARM v7
[b]
Ave FPS Ave (ms/frame) Ave Upload/(ms) Min Upload (ms)
[/b]
3xGL_ALPHA, STANDALONE
[512x512 texture] 46.7 10.78 17.23 5.86
3 x GL_ALPHA, in GAME
[512x512 texture] 11.2 72.13 49.01 22.29
[256x256 texture] 16.6 42.41 40.38 23.16
GL_RGBA, in GAME
[512x512 texture] 10.6 68.08 42.73 15.05
[256x256 texture] 11.9 50.57 40.95 23.00
Samsung Tab 2 P3100 1GB RAM [1024 x 600] Dual Core
GPU: PowerVR SGX540 CPU: ARM v7
[b]
[/b]
[512x512 texture] 54.9 5.59 7.73 1.86
3xGL_ALPHA, in GAME
[512x512 texture] 35.8 7.16 6.63 3.75
[256x256 texture] 34.9 4.47 4.42 1.4
GL_RGBA, in GAME
[512x512 texture] 16.1 42.37 12.65 8.97
[256x256 texture] 31.8 10.43 4.72 3.20
I am uploading 3 textures each using the following OpenGL call
glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, textures->width, textures->height, GL_ALPHA, GL_UNSIGNED_BYTE, static_cast<char *>(bp_src->YPlane.Buffer));
As you can see - packing the three textures into a single RGBA (there is option for alpha but it’s not used yet) texture helps with upload speed a bit but not enough to offset having to copy the data from 3 separate buffers into one block of memory for a single glTexSubImage call.
The main point is that these texture speeds are horribly slow - the Samsung Tab 2 speeds are bareable but are still slow compared to newer h/w Is there something I can do to optimize this or some work around for devices with such slow uploads ?
