File “/usr/local/bin/tlt-dataset-convert”, line 8, in
sys.exit(main())
File “./detectnet_v2/scripts/dataset_convert.py”, line 64, in main
File “./detectnet_v2/dataio/dataset_converter_lib.py”, line 74, in convert
File “./detectnet_v2/dataio/dataset_converter_lib.py”, line 108, in _write_partitions
File “./detectnet_v2/dataio/dataset_converter_lib.py”, line 149, in _write_shard
File “./detectnet_v2/dataio/kitti_converter_lib.py”, line 169, in _create_example_proto
File “./detectnet_v2/dataio/kitti_converter_lib.py”, line 265, in _add_targets
UnicodeEncodeError: ‘ascii’ codec can’t encode characters in position 0-12: ordinal not in range(128)
What parameter out of the 15 columns is causing this issue? Is there a way to figure out what it is and fix the issue.
