Platform : nvidia Xavier
using JetPack 4.1 to install xavier OS / CUDA / cudnn / TensorRT
Jetpack : 4.1
Tensorrt : tensorrt_5.0.3.2-1+cuda10.0_arm64
Tensorflow : tensorflow_gpu-1.12.0rc2+nv18.11-cp36-cp36m-linux_aarch64.whl
Problem:
Can’t find a device placement for the op!
link for inv3.pb
https://smasoft-my.sharepoint.com/:u:/g/personal/tom_huang_smasoft_com_tw/ERg5hC2AVdpHgHLUIkgBQQUBghXf2zrP5es3ZVoQqo5Gvg?e=4hbQSf
import tensorflow as tf
import tensorflow.contrib.tensorrt as trt
fn = 'trt_graph10_'+FP
frozen_graph_fn='inv3.pb'
output_name='prediction'
input_name = 'input'
with tf.gfile.GFile(frozen_graph_fn,'rb') as f:
graph_def = tf.GraphDef()
graph_def.ParseFromString(f.read())
trt_graph = trt.create_inference_graph(
input_graph_def=graph_def,
outputs=[output_name],
max_batch_size=1,
max_workspace_size_bytes=1342177280,
precision_mode='FP'+FP,
minimum_segment_size=50
terminal output:
2018-11-27 13:53:16.707869: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:924] ARM64 does not support NUMA - returning NUMA node zero
2018-11-27 13:53:16.708342: I tensorflow/core/grappler/devices.cc:51] Number of eligible GPUs (core count >= 8): 1
2018-11-27 13:53:16.709143: I tensorflow/core/grappler/clusters/single_machine.cc:359] Starting new session
2018-11-27 13:53:16.739946: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Found device 0 with properties:
name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.5
pciBusID: 0000:00:00.0
totalMemory: 15.45GiB freeMemory: 9.48GiB
2018-11-27 13:53:16.740300: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1511] Adding visible gpu devices: 0
2018-11-27 13:53:20.110821: I tensorflow/core/common_runtime/gpu/gpu_device.cc:982] Device interconnect StreamExecutor with strength 1 edge matrix:
2018-11-27 13:53:20.111248: I tensorflow/core/common_runtime/gpu/gpu_device.cc:988] 0
2018-11-27 13:53:20.111336: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1001] 0: N
2018-11-27 13:53:20.111848: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 8494 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2018-11-27 13:53:25.941717: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:3056] Segment @scope 'InceptionV3/', converted to graph
2018-11-27 13:53:25.942199: E tensorflow/contrib/tensorrt/convert/convert_graph.cc:418] Can't find a device placement for the op!
2018-11-27 13:54:52.317595: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:952] Engine InceptionV3/my_trt_op_0 creation for segment 0, composed of 793 nodes succeeded.
2018-11-27 13:54:54.331525: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must *NOT* be called on function objects.
2018-11-27 13:54:54.962589: W tensorflow/contrib/tensorrt/convert/trt_optimization_pass.cc:185] TensorRTOptimizer is probably called on funcdef! This optimizer must *NOT* be called on function objects.
2018-11-27 13:54:55.138503: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: tf_graph
2018-11-27 13:54:55.138813: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 802 nodes (-386), 836 edges (-386), time = 1548.64197ms.
2018-11-27 13:54:55.138878: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Graph size after: 817 nodes (15), 840 edges (4), time = 386.45ms.
2018-11-27 13:54:55.138922: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 25 nodes (-792), 13 edges (-827), time = 87273.8125ms.
2018-11-27 13:54:55.139067: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 14 nodes (-11), 13 edges (0), time = 161.317ms.
2018-11-27 13:54:55.139120: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 14 nodes (0), 13 edges (0), time = 393.6ms.
2018-11-27 13:54:55.139162: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:501] Optimization results for grappler item: InceptionV3/my_trt_op_0_native_segment
2018-11-27 13:54:55.139204: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 794 nodes (0), 828 edges (0), time = 868.905ms.
2018-11-27 13:54:55.139244: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] layout: Invalid argument: The graph is already optimized by layout optimizer.
2018-11-27 13:54:55.139295: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 794 nodes (0), 828 edges (0), time = 56.107ms.
2018-11-27 13:54:55.139341: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] constant folding: Graph size after: 794 nodes (0), 828 edges (0), time = 576.317ms.
2018-11-27 13:54:55.139439: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:503] TensorRTOptimizer: Graph size after: 794 nodes (0), 828 edges (0), time = 56.435ms.
