hello, I have tried to make my model’s input layer default input from (None, None, 1) to (1408, 960, 1 ), in order to make all the layers input is known and create a static model in TF-TRT
My model is retinaet model backbone is resnet-50, but when I use the TF-TRT API to create the static model, there are some problems happen. the log is :
2019-12-23 18:25:24.610102: W tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:737] TensorRT node gn2a_branch2c/TRTEngineOp_69 added for segment 69 consisting of 15 nodes failed: Internal: Input shapes must be fully defined when in static mode. Please try is_dynamic_op=True (shape was [?,32,?,?,8]). Fallback to TF…
2019-12-23 18:25:24.610109: W tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:737] TensorRT node gn2a_branch2c/TRTEngineOp_70 added for segment 70 consisting of 4 nodes failed: Internal: Input shapes must be fully defined when in static mode. Please try is_dynamic_op=True (shape was [?,32,?,?,8]). Fallback to TF…
2019-12-23 18:25:24.610115: W tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:737] TensorRT node gn2b_branch2a/TRTEngineOp_71 added for segment 71 consisting of 15 nodes failed: Internal: Input shapes must be fully defined when in static mode. Please try is_dynamic_op=True (shape was [?,32,?,?,2]). Fallback to TF…
It means that I also have a lot of place’ input shapes are not defined , and only 17 TRTEngineOp generate, but if I choose the (is_dynamic_op=True, there are 204 TRTEngineOp generate), why these kind of thing happen? my code of TF-TRT is as below:
converter = trt.TrtGraphConverter(
input_graph_def=frozen_graph,
nodes_blacklist=return_elements, #output nodes
max_batch_size=32,
is_dynamic_op=False,
max_workspace_size_bytes=1<<30,
precision_mode=trt.TrtPrecisionMode.FP32,
minimum_segment_size=1,
maximum_cached_engines=100)
trt_graph = converter.convert()
and my model is :
model.inputs
model.outputs
model.summary()
[<tf.Tensor ‘input_1:0’ shape=(?, 1408, 960, 1) dtype=float32>]
[<tf.Tensor ‘filtered_detections/map/TensorArrayStack/TensorArrayGatherV3:0’ shape=(?, 300, 4) dtype=float32>, <tf.Tensor ‘filtered_detections/map/TensorArrayStack_1/TensorArrayGatherV3:0’ shape=(?, 300) dtype=float32>, <tf.Tensor ‘filtered_detections/map/TensorArrayStack_2/TensorArrayGatherV3:0’ shape=(?, 300) dtype=int32>]
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 1408, 960, 1) 0
padding_conv1 (ZeroPadding2D) (None, 1414, 966, 1) 0 input_1[0][0]
conv1 (Conv2D) (None, 704, 480, 64) 3136 padding_conv1[0][0]
gn_conv1 (GroupNormalization) (None, 704, 480, 64) 128 conv1[0][0]
conv1_relu (Activation) (None, 704, 480, 64) 0 gn_conv1[0][0]
pool1 (MaxPooling2D) (None, 352, 240, 64) 0 conv1_relu[0][0]
res2a_branch2a (Conv2D) (None, 352, 240, 64) 4096 pool1[0][0]
gn2a_branch2a (GroupNormalizati (None, 352, 240, 64) 128 res2a_branch2a[0][0]
res2a_branch2a_relu (Activation (None, 352, 240, 64) 0 gn2a_branch2a[0][0]
padding2a_branch2b (ZeroPadding (None, 354, 242, 64) 0 res2a_branch2a_relu[0][0]
res2a_branch2b (Conv2D) (None, 352, 240, 64) 36864 padding2a_branch2b[0][0]
gn2a_branch2b (GroupNormalizati (None, 352, 240, 64) 128 res2a_branch2b[0][0]
res2a_branch2b_relu (Activation (None, 352, 240, 64) 0 gn2a_branch2b[0][0]
res2a_branch2c (Conv2D) (None, 352, 240, 256 16384 res2a_branch2b_relu[0][0]
res2a_branch1 (Conv2D) (None, 352, 240, 256 16384 pool1[0][0]
gn2a_branch2c (GroupNormalizati (None, 352, 240, 256 512 res2a_branch2c[0][0]
gn2a_branch1 (GroupNormalizatio (None, 352, 240, 256 512 res2a_branch1[0][0]
res2a (Add) (None, 352, 240, 256 0 gn2a_branch2c[0][0]
gn2a_branch1[0][0]
res2a_relu (Activation) (None, 352, 240, 256 0 res2a[0][0]
res2b_branch2a (Conv2D) (None, 352, 240, 64) 16384 res2a_relu[0][0]
gn2b_branch2a (GroupNormalizati (None, 352, 240, 64) 128 res2b_branch2a[0][0]
res2b_branch2a_relu (Activation (None, 352, 240, 64) 0 gn2b_branch2a[0][0]
padding2b_branch2b (ZeroPadding (None, 354, 242, 64) 0 res2b_branch2a_relu[0][0]
boxes (RegressBoxes) (None, 1125520, 4) 0 anchors[0][0]
regression[0][0]
classification_submodel (Model) multiple 4573120 P3[0][0]
P4[0][0]
P5[0][0]
P6[0][0]
P7[0][0]
clipped_boxes (ClipBoxes) (None, 1125520, 4) 0 input_1[0][0]
boxes[0][0]
classification (Concatenate) (None, 1125520, 24) 0 classification_submodel[1][0]
classification_submodel[2][0]
classification_submodel[3][0]
classification_submodel[4][0]
classification_submodel[5][0]
filtered_detections (FilterDete [(None, 300, 4), (No 0 clipped_boxes[0][0]
classification[0][0]
Total params: 44,381,604
Trainable params: 44,381,604
Non-trainable params: 0
what should I do if I want to create a static model?
Thank you in advance
