TF-TRT Model recompiles when loading it in a different Python Scope
Description
When retrieving the callable tftrt function in a difference Python Scope as the actual inference scope, the model recompiles for several minutes before it can be executed. Self-explanatory example below.
Environment
I use the latest TensorFlow NGC Container
Container : nvcr.io/nvidia/tensorflow:23.06-tf2-py3
TensorRT Version: 8.6.1
GPU Type: NVIDIA GeForce RTX 2080, compute capability: 7.5
Nvidia Driver Version: Driver Version: 525.125.06
Relevant Files
TFTRT_FP16_tensorflow_23_06_tf2_py3 - Model - Google Drive
Steps To Reproduce
Needs to recompile Model for 2 min:
import time
import tensorflow as tf
from tensorflow.python.saved_model import tag_constants, signature_constants
def get_infer(path):
    saved_model_loaded = tf.saved_model.load(path, tags=[tag_constants.SERVING])
    infer = saved_model_loaded.signatures[signature_constants.DEFAULT_SERVING_SIGNATURE_DEF_KEY]
    return infer
infer = get_infer("TFTRT_FP16_tensorflow_23_06_tf2_py3")
max_num_points = 35000
num_benchmark_samples = 500
random_input = {
    "points_xyz": tf.random.normal(shape=(1, max_num_points, 3), dtype=tf.float32),
    "points_feature": tf.random.normal(shape=(1, max_num_points, 1), dtype=tf.float32),
    "points_mask": tf.ones((1, max_num_points), dtype=tf.float32)
print("WARM UP")
for i in range(10):
    infer(**random_input)
print("BENCHMARK")
start_serving = time.time()
for i in range(num_benchmark_samples):
total_time_serving = (time.time() - start_serving)
sample_time_serving = total_time_serving / num_benchmark_samples
print("Sample Time:", sample_time_serving)
print("Total Time", total_time_serving)
Output:
python3 test.py
2023-07-27 19:10:24.196040: I tensorflow/core/platform/cpu_feature_guard.cc:183] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: SSE3 SSE4.1 SSE4.2 AVX, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2023-07-27 19:10:25.847417: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.853184: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.853334: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.854591: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.854814: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.854930: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.911404: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.911528: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.911681: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:10:25.911836: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1638] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 5804 MB memory:  -> device: 0, name: NVIDIA GeForce RTX 2080, pci bus id: 0000:01:00.0, compute capability: 7.5
2023-07-27 19:10:26.039557: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
         [[{{node tensorrtinputph_1}}]]
2023-07-27 19:10:26.039676: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
         [[{{node tensorrtinputph_0}}]]
2023-07-27 19:10:26.096927: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32
         [[{{node tensorrtinputph_3}}]]
2023-07-27 19:10:26.097022: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:10:26.097132: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.097235: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.120702: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32 and shape [1]
2023-07-27 19:10:26.120809: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.132721: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_6' with dtype int32 and shape [1]
         [[{{node tensorrtinputph_6}}]]
2023-07-27 19:10:26.132810: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_12' with dtype int32 and shape [1]
         [[{{node tensorrtinputph_12}}]]
2023-07-27 19:10:26.132980: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_7' with dtype int32
         [[{{node tensorrtinputph_7}}]]
2023-07-27 19:10:26.133083: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_13' with dtype int32
         [[{{node tensorrtinputph_13}}]]
2023-07-27 19:10:26.150029: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32 and shape [1]
2023-07-27 19:10:26.150194: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.162776: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:10:26.162855: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_2' with dtype int32
         [[{{node tensorrtinputph_2}}]]
2023-07-27 19:10:26.162964: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.163041: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.173078: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:10:26.173166: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:10:26.433626: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:10:26.433700: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:10:26.433768: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
         [[{{node tensorrtinputph_9}}]]
2023-07-27 19:10:26.433836: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:10:26.434033: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:10:26.434086: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:10:26.434143: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:10:26.434190: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:10:26.828166: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.846028: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.865091: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.882899: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.901089: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.920000: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.937997: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.959532: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.976574: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:26.993085: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.009680: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.031044: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.052213: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.069001: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.086705: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.105033: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.121895: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.138222: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.159360: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:10:27.182225: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
WARM UP
2023-07-27 19:10:27.643235: I tensorflow/compiler/tf2tensorrt/common/utils.cc:104] Linked TensorRT version: 8.6.1
2023-07-27 19:10:27.643269: I tensorflow/compiler/tf2tensorrt/common/utils.cc:106] Loaded TensorRT version: 8.6.1
2023-07-27 19:10:32.108580: I tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:1368] [TF-TRT] Sparse compute capability: enabled.
2023-07-27 19:10:32.112100: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:10:55.644451: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:10:55.644480: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_3 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:10:55.644488: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_7 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:10:55.644494: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_9 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.352753: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.352784: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.358792: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.358821: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.359178: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.359193: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:05.359216: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_2 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:10.346159: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:10.346186: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:20.152008: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_6 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:20.152036: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_7 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:20.152043: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_12 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:20.152049: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_13 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:20.884243: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger TensorRT encountered issues when converting weights between types and that could affect accuracy.
2023-07-27 19:11:20.884266: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger Check verbose logs for the list of affected weights.
2023-07-27 19:11:20.884273: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger - 2 weights are affected by this issue: Detected subnormal FP16 values.
2023-07-27 19:11:25.387574: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:25.387605: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:25.387612: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_3 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:11:35.985833: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger TensorRT encountered issues when converting weights between types and that could affect accuracy.
2023-07-27 19:11:35.985861: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger Check verbose logs for the list of affected weights.
2023-07-27 19:11:35.985873: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger - 2 weights are affected by this issue: Detected FP32 infinity values and converted them to corresponding FP16 infinity.
2023-07-27 19:11:36.094496: I tensorflow/compiler/xla/stream_executor/cuda/cuda_dnn.cc:424] Loaded cuDNN version 8902
2023-07-27 19:12:01.088585: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_5 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:12:01.088613: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_6 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:12:01.088619: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_8 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:12:01.088625: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_9 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:12:29.149202: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_0 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:12:29.149230: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger [RemoveDeadLayers] Input Tensor TensorRTInputPH_1 is unused or used only at compile-time, but is not being removed.
2023-07-27 19:12:33.072846: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger TensorRT encountered issues when converting weights between types and that could affect accuracy.
2023-07-27 19:12:33.072873: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger Check verbose logs for the list of affected weights.
2023-07-27 19:12:33.072881: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger - 1 weights are affected by this issue: Detected FP32 infinity values and converted them to corresponding FP16 infinity.
2023-07-27 19:12:58.553609: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger TensorRT encountered issues when converting weights between types and that could affect accuracy.
2023-07-27 19:12:58.553642: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger Check verbose logs for the list of affected weights.
2023-07-27 19:12:58.553649: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger - 1 weights are affected by this issue: Detected subnormal FP16 values.
BENCHMARK
Sample Time: 0.025833381175994874
Total Time 12.916690587997437
Works perfectly:
import time
saved_model_loaded = tf.saved_model.load("TFTRT_FP16_tensorflow_23_06_tf2_py3", tags=[tag_constants.SERVING])
random_input = {
print("WARM UP")
for i in range(10):
print("BENCHMARK")
Output:
python3 test.py
2023-07-27 19:19:27.223512: I tensorflow/core/platform/cpu_feature_guard.cc:183] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
2023-07-27 19:19:28.839404: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.844423: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.844553: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.845513: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.845635: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.845731: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.911197: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.911319: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.911450: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:1013] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero. See more at https://github.com/torvalds/linux/blob/v6.0/Documentation/ABI/testing/sysfs-bus-pci#L344-L355
2023-07-27 19:19:28.911562: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1638] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 5847 MB memory:  -> device: 0, name: NVIDIA GeForce RTX 2080, pci bus id: 0000:01:00.0, compute capability: 7.5
2023-07-27 19:19:29.038072: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:19:29.038191: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.095586: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32
2023-07-27 19:19:29.095681: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:19:29.095833: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.095899: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.120575: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32 and shape [1]
2023-07-27 19:19:29.120681: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.132949: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_6' with dtype int32 and shape [1]
2023-07-27 19:19:29.133039: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_12' with dtype int32 and shape [1]
2023-07-27 19:19:29.133192: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_7' with dtype int32
2023-07-27 19:19:29.133256: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_13' with dtype int32
2023-07-27 19:19:29.150163: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32 and shape [1]
2023-07-27 19:19:29.150273: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.163103: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:19:29.163194: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_2' with dtype int32
2023-07-27 19:19:29.163287: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.163376: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.173219: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_0' with dtype int32
2023-07-27 19:19:29.173300: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_1' with dtype int32
2023-07-27 19:19:29.430662: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:19:29.430752: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:19:29.430894: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:19:29.430988: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:19:29.431235: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:19:29.431298: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_3' with dtype int32 and shape [2]
2023-07-27 19:19:29.431373: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:19:29.431421: I tensorflow/core/common_runtime/executor.cc:1209] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'tensorrtinputph_9' with dtype int32 and shape [2]
2023-07-27 19:19:29.867512: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.884764: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.902961: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.920449: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.937932: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.955109: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.972425: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:29.990049: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.007372: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.023828: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.040267: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.061583: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.082705: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.099880: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.117366: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.134929: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.152473: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.168648: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.190520: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
2023-07-27 19:19:30.214712: E tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:87] DefaultLogger 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
WARM UP
2023-07-27 19:19:30.697825: I tensorflow/compiler/xla/stream_executor/cuda/cuda_dnn.cc:424] Loaded cuDNN version 8902
BENCHMARK
Sample Time: 0.027252508640289306
Total Time 13.626254320144653
Okay, I figured it out. saved_model_loaded needs to live when calling the callable infer.
This solves the problem
    return infer, saved_model_loaded
infer, saved_model_loaded = get_infer("TFTRT_FP16_tensorflow_23_06_tf2_py3")
The problem actually occurred for me when I stored the callable into a class attribute self.infer. So, make sure that you also store saved_model_loaded into a class attribute when you want to call the inference function somewhere else (self.saved_model_loaded).
Should be added to the documentation
https://docs.nvidia.com/deeplearning/frameworks/tf-trt-user-guide/index.html#python-example
