What am I trying to do:
- With an already trained TF model(frozen), I restored it and successfully optimized it by calling TRT python API. Then I exported the optimized model to saved_model. Then I coded a new script that intended to load the saved_model and do the inference. A CUDA malloc related ERROR popped up.
Log:
2018-05-03 10:08:10.710528: I tensorflow/core/platform/cpu_feature_guard.cc:140] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2018-05-03 10:08:11.315302: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:898] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2018-05-03 10:08:11.315719: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1344] Found device 0 with properties:
name: Tesla P4 major: 6 minor: 1 memoryClockRate(GHz): 1.1135
pciBusID: 0000:00:08.0
totalMemory: 7.43GiB freeMemory: 7.31GiB
2018-05-03 10:08:11.315757: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1423] Adding visible gpu devices: 0
2018-05-03 10:08:11.886331: I tensorflow/core/common_runtime/gpu/gpu_device.cc:911] Device interconnect StreamExecutor with strength 1 edge matrix:
2018-05-03 10:08:11.886496: I tensorflow/core/common_runtime/gpu/gpu_device.cc:917] 0
2018-05-03 10:08:11.886574: I tensorflow/core/common_runtime/gpu/gpu_device.cc:930] 0: N
2018-05-03 10:08:11.886928: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1041] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 7046 MB memory) -> physical GPU (device: 0, name: Tesla P4, pci bus id: 0000:00:08.0, compute capability: 6.1)
import/PermConstNCHWToNHWC-LayoutOptimizer
import/PermConstNHWCToNCHW-LayoutOptimizer
import/Placeholder
import/InceptionV3/InceptionV3/Conv2d_1a_3x3/Conv2D-0-TransposeNHWCToNCHW-LayoutOptimizer
import/InceptionV3/Logits/Conv2d_1c_1x1/BiasAdd-0-0-TransposeNCHWToNHWC-LayoutOptimizer
import/InceptionV3/Logits/SpatialSqueeze
import/InceptionV3/my_trt_op0
Shape
2018-05-03 10:08:14.007927: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger resources.cpp (199) - Cuda Error in gieCudaMalloc: 2
terminate called after throwing an instance of 'nvinfer1::CudaError'
what(): std::exception
My script:
with tf.Session(graph=tf.Graph()) as sess:
tf.saved_model.loader.load(sess, ['serve'], './fs2')
graph = tf.get_default_graph()
for op in tf.get_default_graph().get_operations():
print str(op.name)
inp = graph.get_tensor_by_name("import/Placeholder:0")
oup = graph.get_tensor_by_name("import/InceptionV3/Logits/SpatialSqueeze:0")
sess.run(oup, {inp: batch_input})
I think my overall procedure should be appropriate.
If anyone can share some comments on this, it will be much grateful.
Thanks,
Xiaolun
