TF2 SSD MobileNet V2 model to TensorRT engine file
We’re trying to use a TF2 SSD MobileNet V2 model in a DS pipe but conversion fails. We are using the Jetson Xavier NX eMMC version with L4T R32.6.1.
Current model was used:
download.tensorflow.org/models/object_detection/tf2/20200711/ssd_mobilenet_v2_320x320_coco17_tpu-8.tar.gz
Transfer learning was done using pipeline.config in attachment.
The onnx model is generated using opset 11.
pipeline.config (4.6 KB)
We have the following error when running the DS pipe:
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: onnx2trt_utils.cpp:390: One or more weights outside the range of INT32 was clamped
ERROR: [TRT]: ModelImporter.cpp:720: While parsing node number 264 [TopK -> "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/SortByField/TopKV2:0"]:
ERROR: [TRT]: ModelImporter.cpp:721: --- Begin node ---
ERROR: [TRT]: ModelImporter.cpp:722: input: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/Select:0"
input: "Unsqueeze__600:0"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/SortByField/TopKV2:0"
output: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/SortByField/TopKV2:1"
name: "StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/SortByField/TopKV2"
op_type: "TopK"
attribute {
  i: 1
  type: INT
ERROR: [TRT]: ModelImporter.cpp:723: --- End node ---
ERROR: [TRT]: ModelImporter.cpp:726: ERROR: builtin_op_importers.cpp:4292 In function importTopK:
[8] Assertion failed: (inputs.at(1).is_weights()) && "This version of TensorRT only supports input K as an initializer."
ERROR: Failed to parse onnx file
ERROR: failed to build network since parsing model errors.
What could be wrong?
Kind regards,
Clint
The onnx2trt meet some error when converting the TopK layer.
Based on the log, the value of K should be defined as a constant rather than weight.
You can modify the ONNX model with our graphsurgeon tool below:
