I encounter the following message when trying to capture frame in TGD: ‘Detected unsupported operations that may cause errors or a crash during capture. First seen unsupported operation: glTexParameteri (target = 0x00008D65)’.
If I continue despite the warning, the app crashes and I see the following lines in the log:
03-20 09:33:49.828 5759-5775/com.nativegl.debug I/TegraGfxDebugger﹕ [Frame Debugger Alert] Detected unsupported operations that may cause errors or a crash during capture.
03-20 09:33:49.872 5759-5857/com.nativegl.debug D/GL_DEBUGPRINTF﹕ semMutexCreate implemented as no-op
03-20 09:33:49.918 5759-5859/com.nativegl.debug D/GL_DEBUGPRINTF﹕ semMutexCreate implemented as no-op
03-20 09:33:50.173 5759-5858/com.nativegl.debug A/libc﹕ Fatal signal 11 (SIGSEGV), code 2, fault addr 0xec67f1e0 in tid 5858 (RenderThread)
03-20 09:33:50.284 5740-5740/? I/DEBUG﹕ *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
03-20 09:33:50.284 5740-5740/? I/DEBUG﹕ Build fingerprint: 'google/volantis/flounder:5.0.1/LRX22C/1602158:user/release-keys'
03-20 09:33:50.284 5740-5740/? I/DEBUG﹕ Revision: '0'
03-20 09:33:50.284 5740-5740/? I/DEBUG﹕ ABI: 'arm'
03-20 09:33:50.284 5740-5740/? I/DEBUG﹕ pid: 5759, tid: 5858, name: RenderThread >>> com.nativegl.debug <<<
03-20 09:33:50.285 5740-5740/? I/DEBUG﹕ signal 11 (SIGSEGV), code 2 (SEGV_ACCERR), fault addr 0xec67f1e0
03-20 09:33:50.298 5740-5740/? I/DEBUG﹕ r0 ab49de78 r1 e1e55ba0 r2 ab499a68 r3 ec67f1e0
03-20 09:33:50.298 5740-5740/? I/DEBUG﹕ r4 e1e55ba0 r5 ec6b5cf8 r6 ab49de78 r7 ab8809a8
03-20 09:33:50.298 5740-5740/? I/DEBUG﹕ r8 ab7335b9 r9 00000001 sl ab4998b8 fp e1e55ba0
03-20 09:33:50.298 5740-5740/? I/DEBUG﹕ ip ec6b5d2c sp e1e55a20 lr ec0c2fb3 pc ec67f1e0 cpsr a00f0010
03-20 09:33:50.299 5740-5740/? I/DEBUG﹕ backtrace:
03-20 09:33:50.299 5740-5740/? I/DEBUG﹕ #00 pc 000031e0 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.299 5740-5740/? I/DEBUG﹕ #01 pc 00591fb1 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.299 5740-5740/? I/DEBUG﹕ #02 pc 0054926d /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.300 5740-5740/? I/DEBUG﹕ #03 pc 0054932b /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.300 5740-5740/? I/DEBUG﹕ #04 pc 0061cea3 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.300 5740-5740/? I/DEBUG﹕ #05 pc 0061e3c5 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.301 5740-5740/? I/DEBUG﹕ #06 pc 00568d9d /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.301 5740-5740/? I/DEBUG﹕ #07 pc 00568f27 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.301 5740-5740/? I/DEBUG﹕ #08 pc 00569123 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.302 5740-5740/? I/DEBUG﹕ #09 pc 00648047 /vendor/lib/libTegra_gfx_debugger.so
03-20 09:33:50.302 5740-5740/? I/DEBUG﹕ #10 pc 00015ed3 /system/lib/libc.so (__pthread_start(void*)+30)
03-20 09:33:50.302 5740-5740/? I/DEBUG﹕ #11 pc 00013ea7 /system/lib/libc.so (__start_thread+6)
I’m using Nexus 9 tablet, rooted and running ‘adb insecure’. I can connect to my app in TGD and see graphs, but frame capturing is broken. The app itself is a small experiment with OpenGL ES 3, native code and TextureView overlaying standard Android UI components.
TGD looks very promising, I’d be happy if you help me sort it out. Thank you.
