Hi WayneWWW,
The problem that we encountered after the network was disconnected and not automatically reconnected was that it appeared in different wifi ap or environments.
Hi WayneWWW,
Hi WayneWWW,
Just reappeared!
nvidia@tegra-ubuntu:~ NetworkManager --version
1.2.0
nvidia@tegra-ubuntu:~ [ 1362.431659] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 1362.438851] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=1 from e8:fc:af:f8:9ac
[ 1362.458823] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 1362.571417] cfg80211: World regulatory domain updated:
[ 1362.576565] cfg80211: DFS Master region: unset
[ 1362.581038] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1362.590820] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.598846] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.606844] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.614845] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1362.624337] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1362.633837] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1362.641975] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.650014] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1362.749966] cfg80211: World regulatory domain updated:
[ 1362.755203] cfg80211: DFS Master region: unset
[ 1362.759587] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1362.769339] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.777448] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.785465] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.793521] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1362.803026] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1362.812546] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1362.820640] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1362.828686] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1377.943113] dhd_ndo_remove_ip: ndo ip addr remove failed, retcode = -23
[ 1377.949965] dhd_inet6_work_handler: Removing host ip for NDO failed -23
[ 1379.620214] CFG80211-ERROR) wl_cfg80211_connect : Connectting withe8:fc:af:f8:9a:2c channel (6) ssid “Penguinsinnovate”, len (16)
[ 1379.679316] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with e8:fc:af:f8:9a:2c
[ 1379.703502] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 1379.714887] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with e8:fc:af:f8:9a:2c
[ 1379.809182] cfg80211: Regulatory domain changed to country: CN
[ 1379.815032] cfg80211: DFS Master region: FCC
[ 1379.819250] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1379.829016] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1379.837046] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[ 1379.846931] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 1379.856635] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 1379.865002] cfg80211: (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[ 1379.873714] cfg80211: (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[ 1379.882089] cfg80211: (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[ 1379.905847] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 1379.912044] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 1402.773352] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 1402.780898] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=1 from e8:fc:af:f8:9ac
[ 1402.808140] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 1402.941571] cfg80211: World regulatory domain updated:
[ 1402.946720] cfg80211: DFS Master region: unset
[ 1402.951088] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1402.960833] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1402.968973] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1402.977082] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1402.985285] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1402.995549] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1403.005168] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1403.013565] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1403.021566] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1403.127452] cfg80211: World regulatory domain updated:
[ 1403.133005] cfg80211: DFS Master region: unset
[ 1403.137439] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1403.147285] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1403.155322] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1403.163338] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1403.171866] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1403.181605] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1403.191328] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1403.203441] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1403.211455] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1404.444991] CFG80211-ERROR) wl_cfg80211_connect : Connectting withe8:fc:af:f8:9a:2c channel (11) ssid “Penguinsinnovate”, len (16)
[ 1404.524864] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with e8:fc:af:f8:9a:2c
[ 1404.548665] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 1404.651012] cfg80211: Regulatory domain changed to country: CN
[ 1404.656874] cfg80211: DFS Master region: FCC
[ 1404.661084] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1404.674794] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1404.682807] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[ 1404.692281] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 1404.702013] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 1404.706828] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with e8:fc:af:f8:9a:2c
[ 1404.719763] cfg80211: (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[ 1404.728117] cfg80211: (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[ 1404.736469] cfg80211: (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[ 1413.788896] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH_IND
[ 1413.796420] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 6, reason=15 from e8:fc:af:f8:9ac
[ 1413.940706] cfg80211: World regulatory domain updated:
[ 1413.945871] cfg80211: DFS Master region: unset
[ 1413.950370] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1413.960124] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1413.968279] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1413.976359] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1413.988310] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1413.997784] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1414.007256] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1414.015523] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1414.023737] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1414.125534] cfg80211: World regulatory domain updated:
[ 1414.131027] cfg80211: DFS Master region: unset
[ 1414.135828] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1414.145620] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1414.153658] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1414.161674] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1414.169686] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1414.179157] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1414.188628] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1414.196710] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1414.204704] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1415.509393] CFG80211-ERROR) wl_cfg80211_connect : Connectting withe8:fc:af:f8:9a:2c channel (11) ssid “Penguinsinnovate”, len (16)
[ 1415.564201] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with e8:fc:af:f8:9a:2c
[ 1415.588968] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 1415.664746] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with e8:fc:af:f8:9a:2c
[ 1415.694011] cfg80211: Regulatory domain changed to country: CN
[ 1415.699861] cfg80211: DFS Master region: FCC
[ 1415.704298] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1415.714757] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1415.724149] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[ 1415.733783] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 1415.743379] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 1415.751409] cfg80211: (57240000 KHz - 59400000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[ 1415.759846] cfg80211: (59400000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4400 mBm), (N/A)
[ 1415.768215] cfg80211: (63720000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 2800 mBm), (N/A)
[ 1640.513786] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 1640.521317] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from e8:fc:af:f8:9ac
[ 1640.549014] CFG80211-ERROR) wl_cfg80211_connect : Connectting with50:fa:84:5f:ac:ba channel (6) ssid “Penguinsinnovate”, len (16)
[ 1640.659264] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[ 1640.669072] cfg80211: World regulatory domain updated:
[ 1640.669076] cfg80211: DFS Master region: unset
[ 1640.669076] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1640.669080] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.669082] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.669085] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.669087] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1640.669090] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1640.669092] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1640.669094] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.669096] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1640.773709] CFG80211-ERROR) wl_bss_connect_done : [ 1640.773767] ------------[ cut here ]------------
[ 1640.773770] WARNING: at /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/net/wireless/sme.c:714
[ 1640.773771] Modules linked in: xt_addrtype br_netfilter bcmdhd bluedroid_pm
[ 1640.773777]
[ 1640.773781] CPU: 0 PID: 3151 Comm: kworker/u8:2 Not tainted 4.4.38-tegra #1
[ 1640.773782] Hardware name: jetson_tx1 (DT)
[ 1640.773790] Workqueue: cfg80211 cfg80211_event_work
[ 1640.773792] task: ffffffc0f4891900 ti: ffffffc0fb368000 task.ti: ffffffc0fb368000
[ 1640.773797] PC is at __cfg80211_connect_result+0x1a8/0x234
[ 1640.773800] LR is at __cfg80211_connect_result+0xf0/0x234
[ 1640.773801] pc : [] lr : [] pstate: 40000145
[ 1640.773803] sp : ffffffc0fb36bc90
[ 1640.773804] x29: ffffffc0fb36bca0 x28: 0000000000000000
[ 1640.773807] x27: 0000000000000000 x26: ffffffc001481278
[ 1640.773809] x25: ffffffc0d53b8c18 x24: ffffffc000d73a40
[ 1640.773812] x23: ffffffc0f24670b0 x22: ffffffc0d53b8c18
[ 1640.773814] x21: 0000000000000000 x20: 0000000000000000
[ 1640.773816] x19: ffffffc0f2467000 x18: 0000000000000010
[ 1640.773818] x17: 0000007fa7293f28 x16: 0000007fa7ce7fa0
[ 1640.773821] x15: 003b9aca00000000 x14: 0000000000000000
[ 1640.773823] x13: 0000000000000000 x12: 000000060c06163d
[ 1640.773825] x11: ffffffc000b30b40 x10: 0000000000000001
[ 1640.773827] x9 : 0000000000000010 x8 : ffffffbffc09c2c8
[ 1640.773830] x7 : ffffffc0795d3a88 x6 : 0000000000000002
[ 1640.773832] x5 : 00000000fffffffe x4 : 0000000000000000
[ 1640.773834] x3 : ffffffc0014ba700 x2 : ffffffc0fb36bbe0
[ 1640.773836] x1 : 0000000000000000 x0 : 0000000000000000
[ 1640.773838]
[ 1640.774075] —[ end trace 8aba5ffdf84f827f ]—
[ 1640.774076] Call trace:
[ 1640.774081] [] _cfg80211_connect_result+0x1a8/0x234
[ 1640.774086] [] cfg80211_process_wdev_events+0xe8/0x1a8
[ 1640.774089] [] cfg80211_process_rdev_events+0x4c/0x68
[ 1640.774091] [] cfg80211_event_work+0x1c/0x28
[ 1640.774096] [] process_one_work+0x234/0x45c
[ 1640.774099] [] worker_thread+0x248/0x428
[ 1640.774102] [] kthread+0xf8/0x100
[ 1640.774105] [] ret_from_fork+0x10/0x30
[ 1640.775583] cfg80211: World regulatory domain updated:
[ 1640.775585] cfg80211: DFS Master region: unset[ 1640.775587] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs)
[ 1640.775591] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.775593] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.775595] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.775598] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1640.775601] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1640.775603] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1640.775605] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1640.775607] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1641.078446] Report connect result - connection succeeded
[ 1641.103252] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 50:fa:84:5f:ac:ba
[ 1643.625062] IPVS: Creating netns size=1424 id=4
[ 1666.797721] dhd_ndo_remove_ip: ndo ip addr remove failed, retcode = -23
[ 1666.804480] dhd_inet6_work_handler: Removing host ip for NDO failed -23
[ 1691.720460] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DISASSOC_IND
[ 1691.728286] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 12, reason=8 from 50:fa:84:5f:aca
[ 1691.855430] cfg80211: World regulatory domain updated:
[ 1691.860606] cfg80211: DFS Master region: unset
[ 1691.864974] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1691.874727] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1691.886690] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1691.894689] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1691.902689] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1691.912161] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1691.921635] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1691.929728] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1691.937724] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1692.041617] cfg80211: World regulatory domain updated:
[ 1692.046773] cfg80211: DFS Master region: unset
[ 1692.051131] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1692.060870] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1692.068880] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1692.076876] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1692.088819] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1692.098291] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1692.107760] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1692.115845] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1692.123866] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
nvidia@tegra-ubuntu:~$ ifconfig
wlan0 Link encap:Ethernet HWaddr 00:04:4b:9c:a0:0e
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:8261 errors:0 dropped:0 overruns:0 frame:0
TX packets:2598 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5471850 (5.4 MB) TX bytes:216651 (216.6 KB)
Are you using two AP both with ssid = “Penguinsinnovate”? Just want to make sure I understand your log correctly.
Is wifi ever connected to any one of them and able to see the IP?
Hi WayneWWW,
Only one “Penguinsinnovate” AP,this AP just restarted.
Before ap restarts, the device is always connected to this ap。
“Before ap restarts, the device is always connected to this ap。”
What did this comment meant…?? Does this indicate it works fine or …?
Hi WayneWWW,
The router disconnects the Internet, turns on wifi, the device gets the ipv6 address, and the log prints every one or two minutes.
nvidia@rabbit-9c5cae:~$ [28239.963988] CFG80211-ERROR) wl_cfg80211_disconnect : [28239.964682] dhd_ndo_remove_ip: ndo ip addr remove failed, retcode = -23
[28239.964683] dhd_inet6_work_handler: Removing host ip for NDO failed -23
[28239.982199] Reason 3
[28239.991521] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[28239.998770] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from b4:0f:3b:2c:75:91
[28240.291578] CFG80211-ERROR) wl_cfg80211_disconnect : Link down event is not received
[28240.331054] cfg80211: World regulatory domain updated:
[28240.336210] cfg80211: DFS Master region: unset
[28240.340625] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[28240.350606] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[28240.358681] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[28240.368109] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[28240.376154] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[28240.385692] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[28240.395206] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[28240.403303] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[28240.411305] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[28240.426805] cfg80211: World regulatory domain updated:
[28240.431974] cfg80211: DFS Master region: unset
[28240.436333] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[28240.447201] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[28240.455908] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[28240.465453] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[28240.473472] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[28240.482947] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[28240.492441] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[28240.500537] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[28240.508604] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[28241.845774] CFG80211-ERROR) wl_cfg80211_connect : Connectting withb4:0f:3b:2c:75:91 channel (2) ssid “Tenda_pi”, len (8)
[28241.885057] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with b4:0f:3b:2c:75:91
[28241.913406] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[28241.923795] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with b4:0f:3b:2c:75:91
[28241.967647] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[28241.973859] dhd_inet6_work_handler: Adding host ip for NDO failed -23
I think our discussion has somehow cannot have any conclusion because I cannot get what your usecase is.
Thus, few suggestion and questions for you.
Please tell us what commands are you using for scanning wifi. My suggestion is please use NM gui to scan wifi manually.
Please try different wifi AP and different TX1 for test. Maybe this is specific to one TX1 or AP only.
Why do you mention ipv6 here?
