I have a three-fold cycle in c++, and I want to run it with GPU, so I write such code:
void func()
int i=100,j=100,k=20;
dim3 dimBlock(16,16,1);
dim3 dimGrid(i/dimBlock.x+1, j/dimBlock.y+1, k/dimBlock.z+1);
mykernel<<<dimGrid,dimBlock>>>();
But I always got such error:
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.2/cufft/src/execute.cu, line 1070
cufft: ERROR: CUFFT_EXEC_FAILED
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.2/cufft/src/execute.cu, line 316
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.2/cufft/src/cufft.cu, line 147
i didn’t run cufft in above funcition func(). Why I got an error of cufft?
But when I set the 3rd number of dimGrid to 1, that is, dim3 dimGrid(i/dimBlock.x+1, j/dimBlock.y+1, 1), the error disappear!
Btw, I use the GTX295 and cuda2.2
And I also didn’t find the folder and file shown in the error: cuda-stuff/sw/rel/gpgpu/toolkit/r2.2/cufft/src/execute.cu
thank you.
Geka
June 3, 2009, 10:01pm
2
Grids can be 2D, Blocks can be 3D
From the Programming Guide (section 4.2.3):
It is specified by inserting an
expression of the form <<< Dg, Db, Ns, S >>> between the function name
and the parenthesized argument list, where:
Dg is of type dim3 (see Section 4.3.1.2) and specifies the dimension and size of
the grid, such that Dg.x * Dg.y equals the number of blocks being launched;
Dg.z is unused;
Db is of type dim3 (see Section 4.3.1.2) and specifies the dimension and size of
each block, such that Db.x * Db.y * Db.z equals the number of threads per
block;
YDD
June 4, 2009, 1:05pm
4
A supplemental question… is this limitation going to be relaxed in the future? There are times when being able to launch a 3D grid would be quite nice (and for the far future, I could express the kernel launch for my current project much more easily with a six dimensional grid :D )
I agree with you.
I also hope Nvdia can add the support for multi-dimension grid to cuda.
because in most of case of physics we do the computation in a space which has more than three dimensions.
If nvidia want sale the GPU in scientific filed, I think it is very necessary.
I’m wondering why there’s misslead in documentation:
CUDA C Programming Guide Version 4.0, page 8:
mfatica
September 23, 2011, 3:31pm
7
3D grids are supported in CUDA 4.0 on Fermi GPUs.
PaulV
September 23, 2011, 3:38pm
8
Just now I ran into issues with this as well. It seems that you need both a device with compute ability 2.0 and the CUDA runtime 4.0 to use the third dimension in grids. If I run on a Tesla C2050 (with compute ability 2.0) and CUDA 4.0 it works, but with a GeForce GTX 460 (with compure ability 2.1) and CUDA 3.2 it doesn’t. Maybe I missed something.
njuffa
September 23, 2011, 4:41pm
9
Correct, you need compute capability >= 2.0 and CUDA version >= 4.0 to use three-dimensional grids.
