Jetson Orin
R34.1.1
The physical connection:
GMSL imx390 * 4 —> 4lane MIPI(CSI a+b) —> Orin
The Issue:
The 96712 connected to the fourth camera can cause the other three channels to stall
Without the fourth camera, the other three are fine
Dts config:
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
pixel_phase = "uyvy";
csi_pixel_bit_depth = "8";
dynamic_pixel_bit_depth = "8";
readout_orientation = "0";
line_length = "1920";
inherent_gain = "1";
mclk_multiplier = "5.184";
pix_clk_hz = "124416000";
serdes_pix_clk_hz = "700000000";
The actual 96712 output rate is 1.4Gbps/lane
It feels like the rate bandwidth is not enough!! But in practice 1.4Gbps/lane should theoretically be sufficient
Not sure what the problem is ???
Ask for help, thank you
