I flashing Jetpack 7.1 to my Thor custom board (without EERPOM),at first time I use below command to flash ,and result was good: sudo SKIP_EEPROM_CHECK=1 BOARDID=3834 BOARDSKU=0008 ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
And then I want to enable PCIe C4 . So I ref [Link] to edit tegra264-bpmp-3834-0008-4071-xxxx.dtb、jetson-agx-thor-devkit.conf、tegra264-p4071-0000.dtsi、tegra264-mb1-bct-pinmux-p3834-xxxx-p4071-0000.dtsi
And I test the same way on thor devkit, the result fail too. We conducted this test to demonstrate that our custom carrier board strictly follows the reference design.
Since the Devkit is experiencing the exact same issue, it suggests that our hardware design for USB2-0 is functionally correct and not the root cause of the problem.
I want enable PCIe C3 (default is UFS Mode uphy0-config = <0x07>) too, so I edit <0x07> to <0x06> , my expect I/O on my custom board was include two PCIe channel can use.
I have confirmed that this change was made. You can find it in the jetson-agx-thor-devkit.conf file, which is part of the PCIe_C4_enable.zip I shared at the beginning of our chat.
Ok, I will change one by one instead of modifying all of them to see which part goes into the boot crash. below is my test only modify one set at one time and flash.
Use a clean BSP to test~
uphy0-config = <0x06> (default was <0x07>) (1)tegra264-bpmp-3834-0008-4071-xxxx.dtb、(2)jetson-agx-thor-devkit.conf、(3)tegra264-p4071-0000.dtsi
The difference between #7 and #8 config in uphy1 is only the MGBE setting.
–>You are correct. In that case, is this a bug in Jetpack 7.1? Or could it be a configuration issue on my end, either in hardware or software?
Do you expect to use a 25GB setting here?
→ Yes, I would like to use 25GB setting on my custom board.
Following the guide to configure 25MGBE mode fixed the problem, thanks!"
So for Jetpack 7, is it mandatory to ensure every single configuration is set correctly in the BSP to have a successful flash? If any part is missing, is that what causes the ADB-related errors?
