The AGX Xavier not boot up
Hi teams
Recently,We have a problem that the AGX Xavier did not boot up.
it hold on the boot section.
Could you give me some advice ?
the log is attached.
not-boot.txt (31.9 KB)
BRs
thanks
Did you install anything or modify anything to the board? Why do you mention “recently”? This issue wasn’t there before?
Hi WayneWWW
We haven’t conducted any special tests before, but we found out this problem only recently.
When the main board boot,it will stuck here ,then the debug uart did not output any message.it will not boot.
What factors may lead to this problem ?
If you didn’t do anything special to your board, probably the hardware problem.
  1. Does this issue happen in every boot?
  2. Are you able to reflash the board and see if issue is still?
Hi WayneWWW
1 Does this issue happen in every boot?
I try three times it still like this.
2 Are you able to reflash the board and see if issue is still?
I will try it
