The apk based on Gstreamer dont have a x window output when the machine autostart
i made a script so the application can auto start, but when i enter the desktop, the x11 display dont exist.How i can make a x11 window display? use gtk or the other ui? thanks.
There are some use-cases in
Jetson AGX Orin FAQ
Q: How to autorun an app or commands at startup?
You can try this one:
Mediapipe error Open Gl error in myservice.service - #14 by DaneLLL
my program command is
sudo ./play_video rtsp://192.168.31.xxx:554/live/ch0
when i put it in the autostart script or .xsessionrc, the top command show the program is runing.but when i enter the desktop, it also didnt display .ps: the play video program using the gstreamer api in c, the rtsp url is that my own usb camera support.
May be the startup is the only solution
