I got a strange thing happening. I made a code which is just doing a simple movement of some particles on the cpu and then the positions are copied to the gpu and used to create a density map which then plotted with opengl.
I ran the code on my laptop with 750m gpu and 7.5 kit. no problem.
Next I tried it on to desktop computers, one with 750 and the other with 980 8.0 kit. In both it seem are some problems. If I run it direct the program crashes. If I run it with cuda-memcheck I get the error mentioned, if I include -g -G flags the program now runs but much slower than my laptop. In addition some functions seems to trigger the problem even if they are never called.
I am not sure what happens here. It is a problem with opengl or with CUDA. The error seems to suggest a problem with the pointers, but it only happens on the desktop computers. Where should I start the debugging?
How do I do debugging if I have the opengl calls, so far i was not able to.
Thank you in advance
(short story the program works on my laptop, but not on two other computers)
