The Art of Multi-Node vLLM on DGX Spark: Recipes, Benchmarks, and Black Magic
Hi everyone!
Let me introduce myself: I have a cluster of 16 DGX Spark nodes connected via a switch. I actively use the spark-vllm-docker repository – and I really like its approach: ready-made recipes that deploy without any shamanism. But I want to understand how to go beyond the standard examples and scale efficiently to the whole cluster.
My current practical tasks (what to run and try):
GLM-5.3 (full version) – I want to run it on all 16 nodes in NVFP4.
DeepSeek V4.1 Flash together with GLM-5.3-Flash – I'm ready to allocate 4 nodes for each.
Mimo V2.6 Pro – I also plan to run it on all nodes.
Important note: I’m not trying to save hardware. If the reference recipes say that GLM-5.3-Flash is enough on two nodes, I can allocate four because I need a large context and maximum speed. Let it be twice as many devices, but stability and performance must come first.
Now, the questions that really matter to me:
  1. How to properly use ready-made spark-vllm-docker recipes for the whole cluster? I don’t like the approach of “run the command on node 1, then on node 2”. I want to understand how to do this centrally, from one place — so that the recipe automatically rolls out to all nodes.
  2. Where can I study topics like DFlash and TensorFol? I’m looking for proper sources (documentation, repositories, videos) explaining how these technologies work on GB10 and how to use them for optimization. So far, I have to piece things together from different threads.
  3. How do you evaluate efficiency? What benchmarks do you use for local models on a cluster? I’m interested not only in tokens/sec, but also latency on long contexts, and scaling behavior as the number of nodes increases.
  4. How do you achieve model optimization without losing quality? I want to speed up inference, but not at the cost of degraded results. What methods actually work on Spark in a cluster configuration?
  5. How do people choose non-reference models? When a new model appears on HuggingFace, how do you decide whether to try it on Spark? What signs indicate that a model will work well in a cluster?
  6. How do people generally get into writing mods and their own recipes? Is it through deep dives into vLLM source code, through trial and error, or is there a more methodical path? I’m willing to share my findings, but I want to understand the starting point.
Separately, I want to raise an issue that I think many are concerned about: the forum lacks a unified knowledge base. Knowledge is scattered across threads, the search is inconvenient, and some recipes are hidden in forgotten GitHub repositories. Maybe someone has already compiled or structured this information? It would be great to gather something like a “golden set of recipes and links” for DGX Spark in one place.
If anyone has experience specifically with cluster work on Spark via spark-vllm-docker — I’ll take my hat off to anyone willing to share their experience. I hope this thread becomes a gathering point for everyone who wants to squeeze the most out of GB10.
Look up sparkrun, it is designed for deploying models across clusters, or parts of them.
Sparkrun is a cool project, and I’ve used it. However, it isn’t designed for running on clusters of around 16 nodes. Plus, there were often problems with container images. This doesn’t give me the main thing, namely an understanding of how to shape a custom recipe for our architecture.
It works perfectly fine for 16 nodes. The trick is to define overlapping sub clusters:
Cluster All, node 1-16
Cluster Large_A, node 1-8
Cluster Large_B, node 9-16
Cluster Medium_A, node 1-4
Cluster Medium_B, node 5-8
Cluster Medium_C, node 9-12
Cluster Medium_D, node 13-16
Cluster Small_A, node 1-2
And so on you get the idea. So now you can have sparkrun start GLM-5.3 on Large_A, DSv4.1F on Medium_C and whatever else you want on the remaining 4 nodes.
The problem is primarily not where to run (Sparkrun is a simplified wrapper around spark-vllm-docker), but WHAT and HOW to run, so that it works on our architecture. I don’t want to wait a couple of months for a working recipe on spark-vllm-docker or use the GLM-5.3 recipe with sparkrun, which gives 4 tokens per second.
In that case I wish you good luck with your development efforts.
No one here is going to do it for you just for the fun of it.
I am asking whether you could teach me and give me information on where to find materials for creating my own recipes for my cluster. What approaches should I use, how to optimize all of this, and run it without errors
Your questions are each pretty big questions. I don’t think there’s a guide for this stuff. It is mostly in the forum posts and on GitHub. I think most people are just using their agents to do things for them, so maybe try pointing an agent at these threads or repos and asking it your questions? Here’s the current best recipe that requires 16x. Full Kimi K3 running on 16x GB10 cluster
