The bootloader folder generated by the ‘---massflash’ parameter, which is used by the packaging script during the JetPack 6.2 image compilation for th
In JetPack 5.1.1, using the ---massflash parameter of l4t_initrd_flash.sh generates an mfi_jetson-orin-nano-devkit-nvme folder that can be used for flashing. However, in JetPack 6.2, using the same parameter results in an mfi_jetson-orin-nano-devkit-nvme folder that contains an additional rootfs file, which is quite large.
Is there any way to reduce the size of the mfi_jetson-orin-nano-devkit-nvme folder?
We will do internal review and check.
Will replay once updated.
Thank you for your patience.
